ASUS MeMO Pad HD 7 Logo
Chrise B Posted on Dec 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Asus memo pad hd 7 stuck on installing system update
The tablet is stuck on the installing system update screen and will not advance nor can I turn it off by holding the power button down. If you run the battery down, when you charge it up the screen just comes back.
  • Chrise B Dec 03, 2013
    Does anyone know how to fix this? Or how to reset the tablet? I only purchased this 4 days ago....
Jon
Level 2:
New Friend:
  • Expert 110 Answers
  • Posted on Dec 03, 2013
 Jon
Expert
Level 2:
New Friend:
Answers
110
Questions
0
Helped
11133
Points
211
Testimonial: "Thanx, I would have tried that but I have exchanged the tablet as it was just bought."
3 Related Answers
Will Halftowaite
  • 508 Answers
  • Posted on Nov 04, 2013
SOURCE: My new Asus memo hd 7 will not turn on whatsoever.
Manual? They come with those? never got one with mine. Only thing i do if i am sure it is charged up is to hold the power button until the Google critter comes up. Might be the android one as well. Something comes up but that's all i do after shutting my down and telling it to power off.
Anonymous
  • Posted on Dec 12, 2012
SOURCE: My asus transformer tf300 won't turn on
It is possible you got into APX mode (for transferring files with the device not in the OS using NVFlash. Great if you bricked a device). This mode is Hold VOL UP and tap POWER. In this case, you can try to use the Reset Hole on the left side of the Asus TF300 (between the microHDMI and microSD card). Try it for 3-5 seconds. Another thing you could do is hold the power button for 30 seconds, release, hold it for 3 seconds and see if it boots.
The last thing you could do is hold VOL DOWN and POWER for about 12-15 seconds until some small text appears in the top left.
MalKontent68
Stan
  • 748 Answers
  • Posted on Dec 31, 2009
SOURCE: THE TABLET BATTERY DRAINED DEAD NOW IT WONT POWER
Have the power adaptor checked by an electrician, most probably you will need a replacement.
If you establish that the adaptor is working, then something happened to the battery charging circuitry in your Asus and it will need repair.
If it's still under warranty, then you are good, otherwise it would be better if the adaptor alone failed, as replacement adaptors are rather inexpensive compared to laptop repairs.
Testimonial: "thankyou"
I have a crack on my asus tablet what should I do?
Crack+touch screen not working usually means broken digitizer, which means replacement screen. Usually cost prohibitive in something like the Memo series.
1helpful
2answers
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
How to change top glass of me173x?
Asus MemoPad ME172V Take Apart and Reassembly Nothing Left This is the basic way its done.If you'd like i can do its for you.Call 225-290-5733
Froze whilst playing a game nothing is working
you should go to your tablet setting and check it there.
if you can not find it i suggest you to change your setting to default.
Tablet will not charge or come on.
I did this with my Asus memo pad 7 HD and it worked. http://www.youtube.com/watch?v=PXcQgpISSi8
The difference is only in removing the back cover. Use your nails to pop the cover to prevent damage. Do not use knife. Unplug the battery for 15 minutes than plug back in and pop the rear cover back on. After plugging the charger you should have the battery symbol on the screen. Then leave on the charger until fully charged.
Cant download itv player
go to download itvpplayer to android and then instal it in you memo pad and ready vote please
Asus Memo Pad 7 will not turn on
It did work for a while? I've had occasions where I plugged in my tablet but it didn't charge because the plug wasn't seated correctly. Also I discovered it only worked with one of the cables I have even though any mini USB cable will fit. Do you have another cable you can try to plug into the unit
My asus memo hd 7 will not take a charge or turn on whatsoever..How can I fix this..?
first open your pad check the conector to volt in 4.5v maybe need a rebulding soldering do it then close your pad and work agan vote please
1helpful
Cannot install candy crush on asus memo pad hd 7. I get unknown error code "-24".
You will need to do a factory reset on the device. This should clear up this issue & then you should be able to download the Candy Crush application again afterwards.
Top ASUS Tablets & eReaders Experts
k24674
john h
Ngoro
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
