First, I'm not a AMAZON Kindle Tech.
* If it is "Open" (unlocked) then charge it up using the micro USB slot.
* If you can turn it on and the main menu goes on. Swipe the "Padlock" icon to open. Then swipe from top to bottom to get the menu display (for Kindle fire), Paper white will need to press the mode button (only button on the face of pad)
* If this is still a registered device then the regular menu will pop up and you will need to access the device menu by swiping top of screen downward. Select "+More" which will pull up the "Settings" menu. Select "My Account". Select "Deregister" continue and set up your Amazon account.
* If you want to wipe everything and reset the kindle (as giving it away to someone else) then go to "Settings" menu and select "Device". Select "Reset to Factory Defaults" then follow instructions. This will wipe all data and your account info as well as emails, bank records, etc.
* Resetting the Kindle to factory will be the same as if you just bought it from the store. It will automatically go through the welcome screen and help you set up your kindle and give a short beginner's course.
Aloha, ukeboy57
PS. I found these links that may help:
Reset:
https://www.youtube.com/watch?v=cG2KOxZGBc8
Reset:
https://www.youtube.com/watch?v=6XirQjjOHlE
Reset
https://www.youtube.com/watch?v=XXj8PuYYY4Y
Start Paper White;
https://www.youtube.com/watch?v=0qoxlpUUo0o
Start Paper White;
https://www.youtube.com/watch?v=7cfA6VZ8C28
Fire Start and Review;
https://www.youtube.com/watch?v=-a49TGi16tc
Fire HD10 Start & Review:
https://www.youtube.com/watch?v=zALNY1AS3o0
