I have procured a new washing machine IPX4, Model WA11F5S4. While starting I have connected water outlet hose to the side of the machine. In this condition, the water never remains in the tub. Please let me know do I need to connect the outlet hose to the back of the machine?
SOURCE: Will not advance from fill cycle
Check your drain hose to make sure you have not sealed the top of the standpipe (drain line), or shoved your drain hose too far down in the pipe. If you do not allow for an air gap, your washer will fill and begin to siphon through the drain line. It is common for folks to seal the standpipe or shove the drain hose down in the line too far in the belief that it will prevent overflows, or get rid of that nasty drain smell. This can be bad because it does not allow for the proper air gap to keep the water from being siphoned right out of the machine. You may have a tight fitting that doesn't siphon every time which may explain why the problem doesn't occur all the time. Double check to make sure. Hope this helps.
SOURCE: Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
SOURCE: amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
SOURCE: Washing machine Whirlpool Lsn1000pq1
My washer is doing the same thing. I put it up on blocks so I could see where it was leaking from. On mine it was leaking from the pump which a big white piece of plastic in front of the motor. The pump has two hoses connected to it the **** the water out of the tub and pump it out the drain hose. Disconnect the two hose clamps, remove the hoses (use force). There are two spring clips on top and one bottom. I laid mine on it's side to remove them. There two slots one top, one bottom for you to use when prying the clips off. Place screwdriver under clip and between grove and push/pull until they come off. Carry pump to the sink, fill with water and see if it leaks from somewhere, should be obvious.
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
