This fault is a communication error at the appliance manager, could be a loose wire or a bad display transformer, either way you will need a certified technician to fix this issue, there is no simple plug and go issue to resolve. I personally found the problem to be the transformer not send voltage to the appliance manager. This is solvable but needs someone who understand electronics to correct this issue.
F6 E0 Oven user interface -
lost communication
E6 Oven appliance manager
1 (upper, single) - lost
communication
This is directly from the tech sheet of your oven and directly from the factory web site.
"F2-E6 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly. All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD)."
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
The E6-F2 error code means that the control board thinks there is a problem with the cancel button on the touch pad. Sometimes its due to a loose connection from the ribbon cable on the touch pad. You can push cancel and clear it and if within 5 or under the error code returns the touchpad needs to be replaced. But first check/have the connection checked to make sure its tight. The way modern things work though is grand and Whirlpool say if after replacing touchpad the error code returns once again the clock/control board is what needs to be replaced.
E2 F6 means that your oven temperature sensor has failed as well your electronic control board.
The oven temp sensor, electronic control board and the touchpad must be replaced. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor.
If you are lucky the control board may still be good.
i got a tech sheet for your range accept this message as a fix ya and e mail me at [email protected] and ill send it back as an attachment just say f2 e6 code
