SOURCE: sharp ar5316 blank pages printed and copied.
while standing in front of the copier open the Right door and then then flip down the Front door. Are the levers in place ? usually the front door will not close properly if not. Second take out the toner and look for a loosely hanging piece of plastic on it, give it a tug, does it seem to be a long peice of clear plastic? if yes yank it all the way out. It is a protective piece sent for shipping. It will be on ALL the toners you get. If not look at the right side door there is a back assembly there with either a black cylinder type roller or some strings. Are the strings broken , is the roller in place?
SOURCE: AR-M455 Printing Blank Pages
hi im jules_09.try checking the transfer roller or the drum charge roller or charge wire both of this unit are responsible for blank copy.either there id a current leak on those parts or your drum and transfer power pack is deffective.is the opc drum not expose to light morethan 8minutes?just check the transfer unit then the drum charge wire or roller
SOURCE: sharp AR5516 print blamk pages
enter #interrupt C interrupt 14 start button twice.It shd clear this problem.or else reinstall the drivers
