ITS ANEW CAMERA I TOOK ONR PIC NOW IT SAYS MEMORY FULL AND I CAN'T TAKE ANY MORE PICS
SOURCE: MEMORY FULL ?? CD310CE
if your cam is using a sd card, the card could be locked, theres a little switch on the side of the card try using that and see wat happens. its tiny on one of the sides.
SOURCE: Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
SOURCE: my EX-Z60 reads MEMORY FULL i've only taken 3 pics
I would think that you are using the built-in camera memory, by default it will allow 3 pics.
You need to go to the menu, choose setup and on the 3rd page is Format. Format your memory card
SOURCE: my camera says memory full but doent show any
hi
an alternate solution to this is that try to read te card on uoy pc using a card reader and check to see that the card is empty infact and if it still is genuenly empty then try and format the card once and then try again
cheers
pls rate if this was any help
SOURCE: Kodak c180 camera 1 month old with 5 pics taken.
this camera has a SMALL internal memory, you need to buy a memory card for it , and then you can take thousands of pictures no problem . i had the same issue and the memory card fixed it immediately. :)
