If these are older headphones it's likely that the batteries have gone bad or are defective, if this is a new unit, (aside from returning it for working one) it could still be the batteries, but the other likely issue is the charging unit is defective. you could test with a volt meter to see if it's getting juice. you could also have a short in the headphones somewhere.
SOURCE: No green On/Off light. Charge light is red. I hear only static.
Two things.. Check the batteries..
Also.. since these headphones have to have a signal sent to them to activate transmission (green light simply indicates they are receiving a signal) it can take a few moments after the signal begins to activate them.
I would hazard a guess that when you unplug the cables and then plug them back in.. the feedback that generates activates the base much the same as a regular audio signal would
Finally.. make sure the source is a fixed output.. if not.. and its variable..you will have to increase the output or volume to activate the base..
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
SOURCE: power light blinks on both
Hello.
I have the same problem of blinking lights on both and no sound received...
Have you solved the problem ???
If the answer is yes can you tell ne something more through my mail [email protected] ???
Thank you very much.
