Whirlpool LBT6133AWO CC4104141 Everything works except the agitator post. THe agitator in the bottom of the tub works, but the agitator arm is so loose that it doesn't move and therefore the clothes aren't moved through the water during the wash cycle. The spin cycle works, it is just the wash cycle.
We just washed a huge down comforter, could we have done something to the agitator - moved it off of a locked position?
Ok, sorry it took so long to write. You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you. What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving. During the wash cycle, the top half is just sitting still. If this is wrong, please let me know. If this is right, you have a sort of simple fix. Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off. When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there. You can put your finger on the lips and lift it straight off. Then you will see a cap with a bolt in the center. Remove this bolt (7/16" with long extension). the agitator dogs (Sears part #387091) . You should see these under that last cap tha had the bolt in it. Remove the auger (just slide it up and off), remove the dog holding cap. Remove the dogs, but be sure you remember the way they go back in. Next is the tricky part. Take the cap upside-down, and place it back in the auger. Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole. Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator. Make sure the locks and stuff fit right between the two. Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap). If all goes well and right, you should be able to roll the auger one way and not the other. If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along. Good Luck!!!!! Jim
SOURCE: My whirlpool top loader won't agitate.
Peace Friend,
ngfam1 At your service!
You did nothing to cause this! Things wear out! So is life!
Sounds like the coupling between the transmission and the agitator is broken!
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put
good money into bad!
New appliances are so much more efficient today
that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
I
Same problem but the bolt is so tight I'm afraid to strip it.
I cannot get the outside cap off. It has 3 indents where a screwdriver blade will fit in, but it will not budge. Any suggestions?
lg top loader not agitating properly at washing
what causes a ticking and humming noise during wash cycle
