Top load washer nav5800aww water on floor. unplugged power, pulled front cover,dried up standing water (couple of ounces). took off drain hose, checks ok ,no leaks under pressure. took both hoses off pump no clogs. ran the washer with water only, no leaks from hoses. but after spin cycle had several large drops of water on the base of unit in the center. any help would be great.
Well i'm curious was there anything stuck or naw? Lol i feel like this is a cliff hanger sighsss i must knowwww!?
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
