SanDisk Extreme III 4GB Secure Digital Memory Card Logo
Posted on May 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't download to my computer
After taking many, many pictures with my NIkkon D70 on my Sandisk Extreme III 4 GB at the tulip farm I came home and slid it into my card reader and received a message that there was nothing on the card. I put it back into the camera, viewed the pictures, plugged the camera into the computer and got nothing. I have used this card before, and the readerso I tried another card in the reader and it works fine. What is wrong with the card and why can't I get the pictures on the computer? Thanks for any help, Dawn
Harrie
Level 3:
Top Expert:
  • SanDisk Master 6,746 Answers
  • Posted on Jan 12, 2020
 Harrie
SanDisk Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285912
Points
83153
I'm not surewhere it goes wrong, but please ask someone else if you can use their computer to download your pictures. Or if you have an other card, check if you can make pictures and save some from that card, before you lose the pictures you really want to save.
On your card you should check all golden connections if nothing like dust is on one. And only AFTER YOU DID SAVE the pictures, try to format the card in the camera before reusing. But there always can be an error in your computer or in the USB connector.
5 Related Answers
samkong
Samuel Konger
  • 106 Answers
  • Posted on Nov 02, 2007
SOURCE: Can't format 2Gb Extreme III SD card in Canon G9 camera
Did you try formating with the Camera? Before that, Try formating with Windows Disk manager, then format with the camera, It will solve the problem.
Anonymous
  • 35 Answers
  • Posted on Jan 16, 2008
SOURCE: Err CF
Observe the connector inside camera, using a flashlight. If there is a bent pin take the camera to service immediately. Don't turn it on any more as we did in one similar case - creating a short circuit that damaged the camera electronics and voided the warranty.
If no visible problems, remove battery and leave it out overnight.
Anonymous
  • 94 Answers
  • Posted on Jun 12, 2008
SOURCE: SanDisk Micro SD Card problems.
the card needs to be formated on n73.
if still not work than the card is faulty
Anonymous
  • Posted on Oct 29, 2008
SOURCE: Micro SD 2 GB just stopped working
I had this same issue added music to my card did a safe remove from my comp. placed in phone and it stated "No memory card inserted" and wont read in adapter in computer Im so Sad i lost all my pics/memories :( it just means that the Card is Fried (Burnt Out) no way to fix this their just like SIM cards In 3G phones and if the copper bars get scratched or bent just the slightest bit it kills the SD card.
Anonymous
  • 151 Answers
  • Posted on Jan 01, 2009
SOURCE: Not able to read contents from Memory disk
I)try this rightclick on the drive and select the option 'Explore'
Thanking you
M. Sridhar
Hi, I lost someting like 300 photos all of a sudden and for no reason in the middle of a tour of Costa Rica. I have a Canon PowerShot A720. The card is a SanDisk Extreme III 2.0 GB. My camera doesn't see...
Hello pgaudette1
To recover accidentally erased data , try http://www.recovermemorycards.com/
Probably the data were erased when extracting the card with the camera still " on " , but this is only a supposition .
Best regards ,
fanaudi .
SanDisk Extreme III 4GB, unable to retrieve the 500 images on it.
SanDisk Extreme cards are supposed to ship with RecoveryPro software which should help you get the photos back. If the software is not on your card you may be able to get it from their website or another SanDisk card.
Mar 27, 2010 • Cameras
I have Sandisk Extreme III 4GB memory card why after i shooting photo the file is cannot read?
Make sure your camera is compatible with a 4GB flash card. Some only take 1 or 2 GB cards. If that isn't the issue, format your card inside the camera with the camera's format utility.
Nikon d70 made a folder incorrect
You can download a memory card file recovery software that should let you get to the files. You need to go to the website of the company that made the card and get their software. (Sandisk, Kingston, Transcend, ...etc.) It may cost you money, depending on the card you bought. For instance, the software comes free with Sandisk CF Extreme III's, but not with the regular speed cards. This won't always work, but it usually does. I always format my cards on the PC every time I transfer. You have to format again when you put them into the camera though, so plan ahead before you go shoot.
New Nikon D90 goes into ERR after several shots. only correction is to remove the battery and replace then it resets. I have sandisk extreme III 4 gb memory so speed is not the issue. any thoughts on this?
If the camera is fairly new, the lens is more likely the problem. Try another lens. If the same happens, it's probably a shutter problem.
Jan 04, 2009 • Cameras
Thanking you
M. Sridhar
2helpful
Formatting
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
2helpful
3answers
Nikon D70
Greetings,
It is actually an error message generated by your compact flash and means that the card is no longer readable. A lot of D70 owners have reported this error without being able to find another solution other than reinserting the card or changing the card to a different brand. In my D70s I use Sandisk Extreme III memory and, knock on wood, have not yet had this error. You could also try cleaning out the memory card slot and check to see that all pins are aligned and not bent.
Good Luck,
-WN
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
