Question about Clothing
I need a password for rogers cable internet that will work
Well I got cut off and would like to pirate my cable to receive wireless again
6ya staff
SOURCE:
johnlgrn
John Green
  • 35 Answers
SOURCE: internet router will only work with one computer turned on.it worked with bell but not rogers
Cable sees the mac address of the pc that you hook up and you need to set the router up as a dhcp server and clone the mac address into the router. that will make it work
Johnlgrn
Posted on Dec 31, 2007
Anonymous
SOURCE: Does anyone have the internet functions for Rogers network
I have a gsm phone with a rogers chip. Since it's not a rogers phone it's not hooked up to the internet, nor am I able to get video/picture msgs as a result.
Posted on Jul 30, 2008
Anonymous
  • 4 Answers
SOURCE: need to know how to reset password so neighbors can"t access my internet
You might want to do a hard reset then do all the settings from scratch so you can set a system pass and a wifi pass for the network. use the 128 bit WEP setting.
Posted on May 07, 2009
Anonymous
  • 61 Answers
SOURCE: Set up for the internet with rogers as service provider
there is not WIFI funtion for your phone!!!
www.eshopbing.com mobile phone wholesale
Posted on Sep 28, 2009
Danny1006
Mani Maran
  • 136 Answers
SOURCE: Can connect to internet via ethernet cable but not
Try to check with your ISP for the DHCP lease timings and wireless settings
Posted on Feb 06, 2010
Authentication failed
A Netgear wireless router attaches multiple devices to your Internet connection, either by ethernet cable or wirelessly.
If you can't connect to the Internet, the problem can be anywhere along the chain of devices and technologies that connect your computer to the Internet.
Knowing how to troubleshoot your Netgear or other wireless router is an essential part of determining where the problem is and fixing it.
Click your "Start" button, and choose "Run."
Type "cmd" in the text box (without quotation marks), and click "OK."
A command prompt will open. Type the following: ipconfig /all. Press your "Enter" key.
A list of numbers and other networking configuration information will display.
Find your network adapter in this list of headers.
If you use your computer wirelessly in many different places, you may have to scroll through a lot of different options to find your adapter.
If you connect to the Internet using a cable, look for a header that begins with "Ethernet adapter Local Area Connection."
If you connect wirelessly, look for a header that begins with "Ethernet adapter Wireless Connection."
You will usually only see an IP address displayed under one header in either category.
Record your IP address and default gateway on a piece of paper or in a text file.
If your IP address is 0.0.0.0 or begins with 169.254, unplug your Netgear router from its power source.
Unplug your cable or DSL modem as well.
Be sure to unplug both devices; turning them off with a power switch may not have the same effect.
Wait 20 seconds before plugging the modem in again.
Wait for the lights on the modem to light up.
Plug in your Netgear wireless router again.
Wait for two minutes. Use "ipconfig /all" again.
You should have a different IP address now.
Ping your default gateway.
At the command prompt, type "ping 192.168.1.1" (substituting your default gateway address for 192.168.1.1).
You should receive four responses, all of which will begin with either "Reply from" or "Request timed out."
If you receive "Request timed out," unplug your Netgear wireless router from the power source for 20 seconds, and plug it in again.
Wait two minutes before using "ping" again.
If you receive "Reply from" responses, check to see if your Internet connection is working again.
Open a Web browser. In the address bar, type "http://192.168.1.1" (substituting your default gateway address for 192.168.1.1).
Press "Enter." If you have password-protected your Netgear router, you will be prompted for a username and password.
The default username for a Netgear router is "admin."
When you have successfully entered the username and password, your Web browser will show you the configuration page for your Netgear wireless router.
If your Web browser never loads a Web page or prompts for a username and password, you're not communicating with your Netgear router.
Double-check the address you typed into your address bar.
If you've typed it correctly and your connection is wireless, either your wireless card has a problem or your Netgear router is not correctly sending a wireless signal.
Make sure your wireless card is enabled (using Windows' built-in Network Connections applet or the third-party software that came with your wireless card).
Make sure your connection settings (SSID, security type, and key or passphrase) are correct for your network.
Look at the lights on your Netgear wireless router.
The wireless indicator light should be green.
If it's orange or not on at all, your router is not sending a wireless signal.
Make sure all the settings on your Netgear configuration page are correct.
Most Internet providers use a dynamic IP address and DNS server addresses.
Some Internet providers require a login, and some do not.
To be sure, refer to the configuration information your Internet provider gave you when your Internet access was installed, or call your Internet provider's technical support number.
Click on "Wireless Settings" on the navigation bar on the left-hand side of the page.
If you were not able to reach the configuration page wirelessly and had to connect to your Netgear router with an ethernet cable, make sure these settings are still as you defined them when setting up your network.
If not, either change the settings to suit you, or change the configuration of your wireless card to match these settings.
Be sure to click the "Apply" button if you make any changes.
Click "Router Status" on the navigation bar on the left-hand side of the page.
Under "Internet Port," check your IP address.
If the address begins with 169.254, you're not communicating with your cable or DSL modem. Unplug your cable or DSL modem from its power source for 20 seconds, and plug it back in. Wait two minutes, and refresh this page.
If your IP address still begins with 169.254, there is a problem either with the cable connecting your Netgear wireless router to your cable or DSL modem, or with the modem itself.
If your IP address is 0.0.0.0, there is a problem with your Internet connection, and you should call your Internet provider's technical support.
Record all your configuration information before trying to reset your Netgear wireless router to the factory defaults.
Resetting may fix your problem, but it will wipe out all your configuration information, and you will have to reconfigure your Netgear router from scratch afterward.
To reset most Netgear routers, use the tip of a pen or an unbent paperclip to press and hold the reset button on the back of the router until the test light blinks.
Release the button, and wait two or three minutes.
Connect to the router's configuration page in a Web browser.
Log in with the default username and password, and configure your router.
You may have to connect to the router with an ethernet cable to perform this initial configuration.
Jul 12, 2013 | NetGear Computers & Internet
When i turn on the labtop,I can't get any web sites
Check -
- your wireless switch/button is on (not all laptops have switches)
- your internet modem is working (on-off reset sometimes helps)
- do a virus scan (some bugs kill connection)
- check firewall not blocking internet
- have you used correct wireless password (old windows version don't report bad password - just prevents connection)
- best to connect via cable (setup wireless after confirm internet is good) cable is also faster (do speedcheck with and again with wireless to see wot I mean)
- use another pc/device to test internet (mobile,wii,psp, etc)
- download free and run ccleaner (junk clean out) and spybot (malware finder)
- check in device manager for any problems
- are you in range of wifi (no brainer, but had to mention)
- try system restore to before problem occured
Apr 19, 2013 | Acer Aspire Computers & Internet
N300 dgn2200 no internet connection
How to Troubleshoot a Netgear Wireless Router Print this articleA Netgear wireless router attaches multiple devices to your Internet connection, either by ethernet cable or wirelessly. If you can't connect to the Internet, the problem can be anywhere along the chain of devices and technologies that connect your computer to the Internet. Knowing how to troubleshoot your Netgear or other wireless router is an essential part of determining where the problem is and fixing it.
Instructions
1Click your "Start" button, and choose "Run." Type "cmd" in the text box (without quotation marks), and click "OK." A command prompt will open. Type the following: ipconfig /all. Press your "Enter" key. A list of numbers and other networking configuration information will display.
Find your network adapter in this list of headers. If you use your computer wirelessly in many different places, you may have to scroll through a lot of different options to find your adapter. If you connect to the Internet using a cable, look for a header that begins with "Ethernet adapter Local Area Connection." If you connect wirelessly, look for a header that begins with "Ethernet adapter Wireless Connection." You will usually only see an IP address displayed under one header in either category.
3Record your IP address and default gateway on a piece of paper or in a text file. If your IP address is 0.0.0.0 or begins with 169.254, unplug your Netgear router from its power source. Unplug your cable or DSL modem as well. Be sure to unplug both devices; turning them off with a power switch may not have the same effect. Wait 20 seconds before plugging the modem in again. Wait for the lights on the modem to light up. Plug in your Netgear wireless router again. Wait for two minutes. Use "ipconfig /all" again. You should have a different IP address now.
4Ping your default gateway. At the command prompt, type "ping 192.168.1.1" (substituting your default gateway address for 192.168.1.1). You should receive four responses, all of which will begin with either "Reply from" or "Request timed out." If you receive "Request timed out," unplug your Netgear wireless router from the power source for 20 seconds, and plug it in again. Wait two minutes before using "ping" again. If you receive "Reply from" responses, check to see if your Internet connection is working again.
5Open a Web browser. In the address bar, type "http://192.168.1.1" (substituting your default gateway address for 192.168.1.1). Press "Enter." If you have password-protected your Netgear router, you will be prompted for a username and password. The default username for a Netgear router is "admin." When you have successfully entered the username and password, your Web browser will show you the configuration page for your Netgear wireless router.If your Web browser never loads a Web page or prompts for a username and password, you're not communicating with your Netgear router. Double-check the address you typed into your address bar. If you've typed it correctly and your connection is wireless, either your wireless card has a problem or your Netgear router is not correctly sending a wireless signal. Make sure your wireless card is enabled (using Windows' built-in Network Connections applet or the third-party software that came with your wireless card). Make sure your connection settings (SSID, security type, and key or passphrase) are correct for your network. Look at the lights on your Netgear wireless router. The wireless indicator light should be green. If it's orange or not on at all, your router is not sending a wireless signal.
6
Make sure all the settings on your Netgear configuration page are correct. Most Internet providers use a dynamic IP address and DNS server addresses. Some Internet providers require a login, and some do not. To be sure, refer to the configuration information your Internet provider gave you when your Internet access was installed, or call your Internet provider's technical support number.
7Click on "Wireless Settings" on the navigation bar on the left-hand side of the page. If you were not able to reach the configuration page wirelessly and had to connect to your Netgear router with an ethernet cable, make sure these settings are still as you defined them when setting up your network. If not, either change the settings to suit you, or change the configuration of your wireless card to match these settings. Be sure to click the "Apply" button if you make any changes.
8Click "Router Status" on the navigation bar on the left-hand side of the page. Under "Internet Port," check your IP address. If the address begins with 169.254, you're not communicating with your cable or DSL modem. Unplug your cable or DSL modem from its power source for 20 seconds, and plug it back in. Wait two minutes, and refresh this page.If your IP address still begins with 169.254, there is a problem either with the cable connecting your Netgear wireless router to your cable or DSL modem, or with the modem itself. If your IP address is 0.0.0.0, there is a problem with your Internet connection, and you should call your Internet provider's technical support.
9Record all your configuration information before trying to reset your Netgear wireless router to the factory defaults. Resetting may fix your problem, but it will wipe out all your configuration information, and you will have to reconfigure your Netgear router from scratch afterward. To reset most Netgear routers, use the tip of a pen or an unbent paperclip to press and hold the reset button on the back of the router until the test light blinks. Release the button, and wait two or three minutes. Connect to the router's configuration page in a Web browser. Log in with the default username and password, and configure your router. You may have to connect to the router with an ethernet cable to perform this initial configuration.
Tips & Warnings
You can use the "ipconfig /all" command on almost any computer that connects to a network or the Internet. If "cmd" doesn't open a command prompt, you can use any method your operating system allows to open the prompt or shell. If your Netgear wireless router is not sending a wireless signal even after you've powered it off, waited 20 seconds and powered it back on, you can use an ethernet cable to attach a computer directly to the router to continue troubleshooting.
Jan 07, 2012 | NetGear Computers & Internet
I had to have my computer rebuild, and now I don't know how to get it to work with my wireless network again. I don't remember the password I used, and would be happy to be able to connect with the...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 26, 2011 | Arris Wireless G Broadband Router (wr850g)
Can not send or receive multimedia messages.
Maybe internet is shut off on your phone?
Here are the internet settings for Cingular: Internet Setting Cingular:
Profile Name: Cingular
GPRS setting:
APN: wap.cingular
User Name: WAP @ CINGULARGPRS.COM
Password: CINGULAR1 (ALL UPPERCASE)
Time Out: Off
Primary Gateway IP: 66.209.11.61
Port: 9201
Secondary Gateway IP: 0.0.0.0
Port: 0
DNS Server:BLANK
CSD setting:BLANK
Dial in number NONE
Query at Logon: (NO CHECK MARK)
User Name
Password
Baud Rate Auto
Line Type: ISDN
Time Out Off
DNS Server:
Then go to your browser and enter the following settings:
Profile Name: MEdia Net
Homepage: device.home
Network Link: Cingular
MMS Settings:
Profile Name: MMS over HTTP
MMSC: http : //mmsc.cingular.com/ (No Spaces)
Max Sending Size: 30K
Network Profile: Cingular
and T Mobile: Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
and Fido: Internet Setting FIDO
Profile name: FidoWAP
GPRS setting:
APN: wap.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.11
Port 8080
Secondary Gateway IP: (blank)
Port: (blank)
DNS Server: (unchecked)
CSD Setting:
Dial in number: (blank)
Query at logon: (unchecked)
Username: (blank)
Password: (blank)
Baud Rate: Auto
Line type: Modem
Timeout: Off
DNS server: (unchecked)
Then press Save.
To get MMS working (what I haven't included are the blanks and all boxes should be unchecked unless specified)
Setup-->Data Network
Profile Name: Fido MMS
APN: mms.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.13
Port: 8080
Baud Rate: Auto
Line type: Modem
Timeout: off
Then click SAVE.
THEN
Messages-->Service Setup-->Multimedia Message
Default profile: FidoMMS
(all other settings are to your preference)
Tap the box beside Default Profile and ensure that FidoMMS is the default profile.
Settings for MMS profile goes
Profile name: FidoMMS
MMSC: http://mms.fido.ca
Max Sending Size: (your preference)
Network Profile: Fido MMS
and Rogers: Internet Setting Rogers
Proxy Name: Rogers MMS
Proxy Address: 172.25.0.107
Access Point: Rogers MMS
Home: ((Set whatever page you like here))
Port Number: 8080
Authentication Type: HTTP-BASIC
User Name: media
Password: mda01
Access Point Name: Rogers MMS
APN: media.com
Authentication Type: PAP
User Name: media
Password: mda01
DNS: <>
Linger Time: 180
MMS Accounts (Main Menu -> Messaging -> Messaging Settings -> MMS Settings)
Profile Name: Rogers MMS
Proxy: Rogers MMS
Relay Server URL: http://mms.gprs.rogers.com
Feb 19, 2009 | LG Shine KE970 Cellular Phone
Bought lg vu unlocked, internet doesn't work!
I did the same thing and after a little online sleuthing i found this solution (it works for me)
go to "menu" then "media net" then "browser settings"
Next go to "accounts" then hit "new" (at the top right next to the title "accounts")
fill in dialog boxes as follows
Account name: Rogers (doesn't really matter what you name it, this will just be the name of the network as it shows up in the menu)
Homepage: mymobilehomepage.rogers.com
Connection mode: TCP with Proxy
Proxy Address: 208.200.067.150
Proxy Port Number: 80
Security: Non-secure
Time out: 150
then click where it says MEdia Net and hit "options" then "new"
fill in the following
Connection Title: Rogers (again doesn't matter what you name it)
Authentication: PAP (don't worry about "bearer")
User Name: wapuser1
Password: wap
APN: goam.com
After everything is complete make sure to select your new option at the bottom (where it used to say "MEdia Net" it should now say "Rogers" or whatever you decided to name it)
Finally hit "save" and activate this profile. You should now be able to access the internet from your LG VU
Credit goes to http://www.howardforums.com/archive/topic/1047591-1.html
Jan 08, 2009 | LG Vu CU920 Cellular Phone
Not able to get internet service
So your wireless network is secured, so really before you can get online with it wirelessly you need to put in the correct security key which is calle a WEP/WPA key, since you can access the internet when connected wired to the router what you need to do here is to access the router setup page and get the security key that you need.
This are the steps to do that:
1.connect the computer to the router with a wired
2.on the address bar type 192.168.1.1 it will ask you for a username and password leave the username blank and password is admin, if admin did not work try typing you commonly use password.
3.if you're already on the setup page of the router, just go to wireless tab and there you will see a wireless security sub tab
4.just go to wireless security then get the security from there
5.then connect to your wireless network using that key
If the password didn't work you may need to reset the router adn reconfigure it back I will advice you to call Linksys tech support so thet can walk you through with that , this is the number 800-3267114 they are open 24hrs...
Hope that helps.........
Sep 06, 2008 | Linksys Wireless-G Broadband Router
Cect p168 problem internet & MMS settings with Rogers Canada
I Have a question ... How can I change the theme on the Cect p168 ??
May 19, 2008 | Cell Phones
Wap settings for motorizr z3
Regular rogers wap
(not using phone as modem)
uses navigate plans
http://www.shoprogers.com/store/wir...ng/overview.asp
apn: goam.com
username: wapuser1
password: wap
IP 208.200.067.150.
or
172.025.000.107
Rogers Media settings
(for MMS/PICmessaging)
http://www.shoprogers.com/store/wir...remessaging.asp
apn: media.com
username: media
password: mda01
mms.gprs.rogers.com
ip 172.025.00.107
Rogers internet.com settings
(to use phone as modem. Or is needed for HTML phones, or wap 2.0 phones at this current time.
requires access to a Data access plan
apn: internet.com
username: wapuser1
password: wap
ip: same as goam, 208.200.067.150
Dec 06, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Clothing Logo
281 people viewed this question
Top Clothing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Jim Pattison
Are you a Clothing Expert? Answer questions, earn points and help others
