SOURCE: Ricoh nrg mp 1600 Aficio copier/scanner/printer
MP 1600L copier/printer produces print-outs with small toner dots spread over the paper. How can I solve this problem?
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
SOURCE: trying to connect my ricoh aficio mp 2000 scanner to my computer
You can't do it that way, you need to connect with a parallel printer cable or a USB A to B Cable.
SOURCE: how to install ricoh aficio
if you have user manual read it
do you have driver cd?
In most cases you will find that the Windows drivers found here are
"self-extracting" (.exe) archives. Click the desired file. When
prompted, we recommend setting the destination to your desktop. Create
a new folder and move the archive into it. Click the file, it will then
extract the software and related files inside of your new folder
automatically. Alternately you may extract or move these files to a
floppy disk. Please note that these files will only self-extract if
executed from Windows.
After extracting the files to a disk or a special directory, you
should look for the installation program which is usually called
"setup.exe" or "install.exe", click it to begin installation. If
neither of these files are present, you should look for a text file
containing special instructions called "Readme.txt" or something
similar.
Sometimes there is no installation program because you must install
your driver via the Windows "Add Printer" function. Instructions for
installing printers can be found in the Windows help file.
Our Macintosh Archives are also self-extracting archives. These
files should be downloaded and then executed. The installer will be
present on the desktop when done. Click the installer and follow the
instructions to install.
Types of Printer Drivers:
