Yes, you can reset your old Westinghouse smart TV by using reset codes. The specific code you need may vary depending on the model of your TV. Here are some general steps you can follow to reset your Westinghouse smart TV using reset codes:
Press the power button on your TV to turn it on.
Using your TV remote, press the "Menu" button and navigate to the "Setup" or "Settings" menu.
Look for the "Reset" option and select it.
Enter the reset code for your TV when prompted. The reset code may be a sequence of numbers or a combination of buttons on the remote control.
Follow the on-screen instructions to complete the reset process.
If you don't know the reset code for your Westinghouse smart TV, you can usually find it in the user manual or by contacting Westinghouse customer support. Keep in mind that resetting your TV will erase all custom settings and restore the TV to its factory default settings
gfdc.herokuapp.com/Westinghouse-40-Lcd-Manual.doc
Westinghouse 40 Lcd Manual - gfdc.herokuapp.com ... led 1080p hdtv - westinghouse 40 class 39 5 diag led 1080p hdtv black model dwm40f1y1 c ... lcd hdtv - buy westinghouse uw40t3pw 40 1080p 120hz lcd hdtv led lcd tvs amazon ... 1080p hdtv dvd combo user s manual vk 40f580d tv dvd combo pdf manual download, ...
Go into tv menu.Goto AUDIO SETTING,go down to reset.This will,reset it back to tv factory setting.The sound now,it working trought ur tv speaker again now.
You might try updating the firmware if you can, via a USB drive and downloading it from Westinghouse. It does have risks, and is irreversible. Some people have complained about using wrong version for Westinghouse download, but may have been due to there sometimes being different versions of the same model product with different hardware. Some have complained about different issues arising after updating. Do some research online about you specific product and good luck.
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
