Siemens HF17055GB Microwave Oven Logo
m
manisha Posted on Dec 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove burnt bread smell in siemens microwave
I BURNT bread in the siemens oven and now every time I use the microwave the smell is dispensed. how do i remove this smell? i think it is in the fan of the machine and gets dispelled each time i switch it on.
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Dec 05, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
465967
Points
5959
1 Related Answer
Anonymous
  • Posted on Feb 26, 2008
SOURCE: Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Rag burnt, is it safe to use the micro? The rag burnt badly, there was smoke and a strong bad smell persists. Is it safe to keep on using the micro, what can be done about the smell?
Hello -
It is probably safe to use the microwave oven after removing the burned smell.
I found some methods for removing a burned smell from a microwave.
https://blog.bostonappliance.net/5-foolproof-ways-to-get-burnt-popcorn-smell-out-of-the-microwave/
(Quote)
1. Fill a bowl with 1/2 cup water and 1 tablespoon white vinegar.
  • Microwave it for 4-5 minutes and leave it with the door shut for 10-15 minutes.
  • Steam will loosen smell-causing detritus stuck to the walls. Vinegar absorbs odors, even stubborn ones like burnt popcorn smell.
  • After the waiting period, remove the bowl and wipe the inside of the microwave down with a paper towel
2. Not good enough? Okay - soak a sponge with vinegar.Place some baking soda on top and microwave the sponge for 25 seconds.
  • Wipe the inside of the microwave with the sponge.
  • Don't forget the glass tray and the microwave door.
3. If steps 1-2 don't remove all the grime, soak cotton balls with acetone-free nail polish remover and wipe down the inside of the microwave.
  • Even stubborn stains should come out.
  • Wipe down the inside with soap, then vinegar water, to remove the polish remover.
  • We recommend following through with step 4 to get rid of chemical smells.
4. Banish the remaining smells with the power of citrus.
  • Peel two oranges or slice a lemon in half.
  • Place the orange peels or lemon slices in a bowl of water (1-2 cups).
  • Microwave it for 4 minutes. Watch closely to ensure that the water stays in the bowl and the citrus peels do not burn.
  • If possible, leave the bowl in the microwave (with the door closed) for 12 hours.
  • Too time-consuming, or just not doable for you? That's okay too. Let the bowl sit in the closed microwave for half an hour then, if the burnt smell persists, continue to step 5.
5. Still bad odors in your microwave? Leave an open box of baking soda on your microwave tray overnight.
  • It will neurtalize the odor without adding to the smelly situation in any way.
  • You can also place coffee grounds from your morning coffee in a bowl in the microwave all day while you are at work.
  • If you don't mind coffee smell, you can microwave 2 tablespoons of coffee grounds in a half cup of water for 2-3 minutes to expedite the process.
(End quote)
Best wishes.
How to gt rid of burnt smell inside the microwave from burnt popcorn
Wash with baking soda wipe out clean then wipe down with vinegar
it will eventually go away.
Loud noise followed by a burnt smell coming from the control panel. Not heating up at all.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./.'';
What is the best way to remove burnt smell from microwave. My dgthr burnt macaroni
Put vinegar in a glass and microwave it.
After it boils take it out and clean your microwave with a disposable towel. Hope this helps.
2answers
Smells like burnt wires
It is very possible it may have burnt wire or burnt capacitor. Remove unit, remove top cover and look inside to see if you see any burn marks or burnt wires. Also check fuse to see if it is good or not.
Won't bake bread
you have an electric short and wires and wire covers are probally burnt. do not use take it in for repairs or replacement.
GE spacemaker xl1800 microwave "burnt paper" smell
Hey
There are several things you can do to help git rid of that smell
First get a mild cleaner with bleach (soft scrub ect!) and clean entire oven inside and try getting that scorch mark off! a little pressure should lessen it ! (there is no filter inside! The plastic inside covering holds smells for a long time! you can also put a cup of white vinigar inside warm on high for 1 minute and leave in overnight!
Please take a second and rate my response
Thank You1
Burnt smell in microwave from burnt muffin in a GE microwave
Many solutions are found here:
http://www.google.com/search?hl=en&q=microwave+smell+OR+odor&btnG=Google+Search
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Siemens Microwave Ovens Experts
john h
ADMIN Eric
ADMIN Eric
Bonded Repair
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
