That doesnt solve th original iue of the door not unlocking at the end of the cycle
SOURCE: front load washer
LO means bad door lock switch or conrtol board. to get it open unlock manually by pulling plastic cable located in dispenser where soap is put in.
SOURCE: washer door latch stuck, can't open
ahh..time for "Q" from 007, eh? this interlock feature is a relay controlled issue. Seems that your washer is telling you that it's closed. most likely a relay replacement in control panel area.
SOURCE: Door Lock
on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
SOURCE: Maytag MAH21pddww door locked
hi thanks for the question to unlock the dor manually open the soap door look to the right top inside its a small piece of string pull on it. that should unlock the door thanks the appliance doc
SOURCE: Maytag MAH 3 Door will not unlock.
OK so the MAH3 Front load is what I assume you're talking about. I found this question looking around when I had the same problem.
So not able to find a soluton I just went to work with my screwdriver. To get the door open you do as follows:
1. Unplug the washer and wait for 5-10 minutes. Safety first.
2. At the back of the machine on the top left and right sides there are 2 screws (mine where black I dont know that they all will be) that hold the top plate in place. Remove them.
3. Once the screws are removed put your palms on the top of the washer and push the lid towards the back of the washer. The lid should slide back a bit then you should be able to lift it off. Put it aside for now.
4. You should now be able to see everything inside the washer. Look straight down from the top where the door is. On the right hand side of the door (this might be different if you have it setup to swing the other way) you will see wires leading to the electronic release for the door. The manual release you're looking for sits at the very BOTTOM of the electronic assembly. Snake your hand down past the wires and and the bottom of the black box thing there is a single "stick with a ball at the end" pull that DOWN while you pull the washer door open (maybe have a friend / wife help). You will not be able to see what you're doing at all but it seemed pretty easy once I figured it out.
My problem apparently (and I couldn't tell this with all the clothes inside) seems to be that the water didn't drain all the way? This appears to be while it wasn't releasing the door.
Anyway good luck!
Suspecting that the filter may be blocked preventing the water from draining completely I cleared the filter, checking deep inside to see if there were anything and replaced the cap. The was no visible water in the washer tub
Just replaced the latch assembly.. works great! Unfortunately the washer is still having the same issue. When a cycle is set, start is pressed, the door latch engages the machine then does nothing, just sits there. If the pause/cancel button is pressed, it will not cancel the action, you have to unplug the machine to shut it off them use the manual latch release in the door. There are no codes give, it does nothing except engage the door latch.
Add a CommentCorrection, when you cancel the action, the add a garment light flashes and the door lock light stays lit.
