When I switch on the treadmill...the entire display screen lights up. In each of the time, distance, calories and incline screens the letter U is displayed. In the centre consol the speed/distance fully lights up to give the impression 888. The belt moves to full speed straight away. The speed can only be switched off by pulling the emergency magnet or by switching off at the bottom back of the machine or from the mains. Is there a simple way using a conferation of the available buttons to reset the machine?
Reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
Locate the reset switch on the underside of the treadmill console. Usually the button
SOURCE: Proform L18 treadmill display doesn't work. Incline and speed switches work but no led display
see the diagram attached. Clean it. Test for open or faulty. Tight the connector. God bless you
SOURCE: Nordictrack Commercial 1500 treadmill w/working display BUT unresponsive buttons
Sounds like a cable harness is undone. The cable feeding the panel which has the computer inside (the power feed) is connected, but the cable from the panel back to the motorized parts isn't. The breakaway is a separate circuit that cuts all power to everything. These are my assumptions (I'm not a nordic track expert), but it's a pretty safe bet, likely the connector in the bottom section. Okay, I just looked it up, first Google "nordictrack 1500 manual" one of the first links is a PDF, with a complete parts breakdown. Depending on your specific model, it looks like there is a connector under the top panel where it meets the right post (and a couple of screws will let you lift it up to check it). It may be partially unplugged, check that first since it looks pretty easy to check.
But I think it's going to be in the bottom, in the bottom of the treadmill the wiring splits to different sections. The motor/incline controller cable (a separate cable #106 on one model I looked up, something like NTL09707 or similar) is probably the one that is either broken or unplugged. So although the computer (up top) is sending signals, they aren't reaching where they need to. Anyway, get that manual, and someone handy with screwdrivers and technology, and they should have it figured out quickly.
