Question about Ricoh Aficio Sg 3110Dn - Printer - Color - Ink-Jet
Ricoh aficio sg 3110dn ERROR CODE sc(20200)
Erorr sc 20200
  • Ricoh Master
  • 10,445 Answers
5 Suggested Answers
6ya staff
SOURCE:
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
Anonymous
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
Joseph Micallef
  • 86 Answers
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Posted on Mar 02, 2009
Bernard D'Souza
  • 163 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
How can i clear call service error sc 20252 in rocoh sg 3110dn
Make a telephone call to your local Ricoh servicer and report error code sc 20252.
Jul 31, 2018 | Ricoh Office Equipment & Supplies
How to fix the error sc 20220
If the error you are talking about is SC202, then you have a laser problem. You will need to either replace the Polygon Mirror Motor or the complete Laser Unit if it comes as one assembly.
Jun 14, 2016 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
57000 error
hi
please my SG 3110DN printer came up with this error code : SC 57000
Jan 06, 2014 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Ricoh Aficio Sg 3110Dn erorr code sc (20200)
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
Dec 05, 2013 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Ricoh SG 3110dn, SC 20200
you need change ink collector unit.
Sep 16, 2013 | Ricoh Office Equipment & Supplies
Whats error code sc 28212
Turn off printer remove carts wait 2 minutes but back in and turn on!
Oct 30, 2012 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Ricoh Aficio Sg 3110Dn - Printer - Color - Ink-Jet Logo
3,545 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
