How long is preheat when making wholemeal bread it doesn't start kneading
SOURCE: breadman tr2200 97
The microprocessor in the keypad probably needs to be reset. With the unit unplugged, remove the keypad housing (one screw in back, one on the left side, rock it up enough to get a small screwdriver inside, then push back the soft plastic fingers to release the housing -- force it a bit, you won't break it). You do not need to remove the bottom cover.
Remove the keypad cover (4 screws) and the PC board (one screw). You'll see a factory reset button near the middle of the left side. Press and hold that for a couple of seconds.
If you want to test the unit before re-assembly, hold the PC board so it doesn't short against anything (there's nothing more than 5v on the board, so you won't get shocked), and plug the unit in. The display should appear. Unplug the unit, re-assemble, and then bake some bread!
There is also the possibility that the backup battery on this PC board is bad. Check it with a voltmeter -- it should be about 5v.
SOURCE: Where can I find a replacement breadpan for the breadman tr2200c?
I found the part at
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
http://www.saltoninc.com/
SOURCE: We lost the kneading blade for the Breadman Model N TR520
HI
Go here for spares
https://secure.prodregister.com/prodprotect/applica/bm.shtml
SOURCE: Breadman TR777C Bread Pan is leaking
Hi you need to go here for a replacement
SOURCE: TR440 Breadman won't begin kneading once "start" button is pushed
Hi Mindy.......it takes 30 minutes to PREHEAT this silly machine for wheat bread. I thought I did something wrong, too........I stopped it twice after it preheated for about 15 minutes. I did not want to waste anything so I let it stay in the machine.....I just went to check the machine and it started after 30 minutes of preheating.
I wish they would mention this in the book!!!
Julie from TX
