SOURCE: Fridge wont get cold
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING A PART. THERE IS A BROWN AND ORANGE WIRE TO THE DEFROST SAFTY THERMOST. THE CONNECTOR ON THAT BROWN WIRE MAY HAVE FROZE APART. THE DEFROST SAFETY THERMOSTAT MAY HAVE FAILED. OR CONTROL BOARD MAY HAVE FAILED. BEHIND THE KICK PLATE IN A BAG ATTACHED TO THE BOTTOM OF YOUR REF. CABINET IS A TECH SHEET ON HOW TO FORCE A DEFROST TO CHECK THE SYSTEM.
