Apple iPad 2 Wifi 16GB Logo
j
janine Posted on Dec 06, 2013
Locked ipad 2
My sister died and mother gave me her ipad 2 but it is locked with icloud and I don't know her password.
Erin
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 07, 2013
Erin
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
233
Points
I think you have to take it into the apple store and they will reset it for you
2answers
How to unlock an ipad
If you remember the password of your iPad, it's would be easy. However, you can still refer to below steps to unlock an iPad without password.
It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
restoring-ipad-software-cpmn0ithqpr5j0kd3fh1ly4i-5-0.png For more details, check: How to Unlock iPad
3answers
How do you unlock the Activation Lock on an ipad when you don't know required Apple id or Password
Your apple ID is normally your email and use the FORGOT PASSWORD line they will send a reset to your backup number or email address
2answers
I want to remove icloud activation from my ipad
Steps to delete iCloud account on iPhone/iPad
  1. Tap on the Settings app and then scroll down to find iCloud.
  2. Tap on "iCloud" to open it.
  3. Scroll down until you find "Delete Account" and then tap on that.
  4. Tap on "Delete" again to confirm the deletion of the iCloud account.
I have iPad two and cannot get it to swipe open it said change passcode I did and now I can't get in it
When you enter the wrong password in to your iPad 6 times in a row, you will see a message on the screen saying "iPad is locked" and recommending you to attempt it later. In the event that you attempt too often, your iPad many show the message letting you know "iPad is disabled connect with iTunes".
Try not to stress, we can work it out. So on the off chance that you overlooked iPad screen arrow password, this post will show you how to remove passcode from iPad easily.
Unless you made a backup before you overlooked your password, there isn't an approach to spare your iPhone information. You'll have to restore your gadget, which erases the greater part of your information and settings. The following guide provides you three methods to remove password from iPhone:
1. On the off chance you've adjusted with iTunes, use iTunes.
2. In case you're marked into iCloud and Find My iPhone is empowered, utilize iCloud.
3. In the event that you don't utilize iCloud and you can't match up or interface with iTunes, utilize recovery mode.
http://www.leawo.org/tutorial/how-to-remove-passcode-from-iphone.html
1helpful
ICloud shows constant upgrade, and password popup
To fix this issue you will need to restore your ipad from backup. Go into settings delete all data and restore from a backup on your computer or icloud.
2helpful
4answers
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
