All the sudden the sound is distorted/static. And now the camera won't come on, the lens will not open
Actually those are a part of the ribbon cable assembly to the logic board- how are volume keys? And hold button??? But I'm honestly leaning towards a system infection and for a reason... The speakers and cam are COMPLETELY different components and that is a hell of a coincidence. I'll a leap of faith and assume you've turned it off and on since you've noticed these issue? But it didn't help??? Usually a nice reset of the electric system helps- but here is how to check for an infection easily. Go to your settings menu, choose general and from there -- pick about. At The bottom you I'll find just above the last bar, a link to the "diagnostic and usage data" choose this- and on the next screen choose again! This takes you to some scary. Scary boring programming files... What's most important to know is apple files one left data package here a day - awdd (apple working daily directory) open the top one you see and make sure it is only 20 lines TOPS.... If this is way not what you see.... Clean install time... :(. Use a DFU Wipe and install cause a deep infection it's obviously made it's way to your hardware and you'll need to reprogram the firmware. http://thebigboss.org/guides-iphone-ipod-ipad/dfu-mode Good place to get easy Instructions on the DFU reset! I'd bet anything this is what's up for you!!!
Generally when this happens with the sound on my ipad I turn it off and just leave it for a half hour im not sure of a sure fire solution but that does seem to help for me.
P.s. a full turn off.
