SumacLife Black Blue Trim Titan Edition Micro-Suede Protective Sleeve Carrying Case with Neoprene Bubble Padding for Samsung Galaxy 10.1 inch Android Tablet / Samsung Galaxy Tab 2 10-inch / Samsung Galaxy Note 10.1 inch Android Tablet fits all Models Black Hif Logo
Charles Fulton Jr. Posted on Dec 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My galaxy tablet drains power while off - SumacLife Black Blue Trim Titan Edition Micro-Suede Protective Sleeve Carrying Case with Neoprene Bubble Padding for Samsung Galaxy 10.1 inch Android Tablet / Samsung Galaxy Tab 2 10-inch / Samsung Galaxy Note 10.1 inch Android Tablet fits all Models Black Hif
Tristan Brown
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 80 Answers
  • Posted on Dec 07, 2013
Tristan Brown
Expert
Level 2:
New Friend:
Greenhorn:
Answers
80
Questions
Helped
11825
Points
243
Your battery is still hot maybe
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
My tablet has safe mode in left corner,hOW DO YOU SHUT IT OFF?
Get an Android Tablet out of safe mode - Support Home Page
acer--uk.custhelp.com/app/.../get-an-android-tablet-out-of-safe-mode
How do I get my Android tablet out of safe mode? Use the ... Restart your device by holding the power button, then tap Power off. ... Did this answer help you?
Samsung Galaxy Tab 3: Turn Safe Mode On or Off
www.technipages.com/samsung-galaxy-tab-3-turn-safe-mode-on-or-off
Mar 15, 2014 - Use the Safe Mode feature on the Samsung Galaxy Tab 3 to start the Android OS with the system default software. ... When the Galaxy Tab 3 logo appears on the screen, press and hold the "Volume Up" button. ... Once the device has completely powered off, you can press the "Power ...
Galaxy Tab 4: Enable or Disable Safe Mode - Technipages
www.technipages.com/galaxy-tab-4-safe-mode
Mar 4, 2015 - A tutorial about how to turn Safe Mode off or on for the Samsung GalaxyTab 4 tablet.
Power the Device Up in Safe Mode - Samsung Galaxy Tab 2 ...
Wht if tablet does not turn off after u hold the power button
What to Do When Your Android Phone or Tablet Won't Turn ...
www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
May 16, 2015 - android wont turn on. You turn on your Android phone or tablet by pressing its power button - simple. If that button won't work, your device isn't necessarily broken ... often see an "empty battery" indicator on the screen when you try to turn it on. ... You should only have to hold the Power button down for ten ...
samsung tablet wont turn on - Samsung - Android Tablets - Tom's Guide
www.tomsguide.com/forum/id-2155281/samsung-tablet-wont-turn.html
3 days ago - 43 posts - ‎36 authors
Why is it locked up with the green robot showing?
may have to many programes running in back ground try disabling google play services temporarily then monitor battery discharge
How do I turn my Samsung galaxy 10.1 2014 edition tablet on
hi,
to turn your
Samsung galaxy 10.1 2014 edition tablet on you need to long press the power button which is at the top-right side of the tablet.Hope youo get your problem fixed. Thanx
1helpful
My galaxy tablet just went dark. No screen or power. It was more than 50% charged last I looked an hour before. It has been plugged in for 20 minutes now and it won't turn on. What happened??
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
5helpful
Tablet is frozen will not activate, plug into wall or usb tablet comes alive but no touch to turn on. Appears locked up, no way to take battery out for reset. any ideas
Try one of the following:
- Hold the power button for 10 seconds
- Hold the power and up volume for 10 seconds for recovery mode
- Hold the powe and down volume for download mode for 10 seconds
If none of these work then your battery might be completely drained and dead. I suggest you send your contact Samsung Support.
Hope this helps.
Top SumacLife Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a SumacLife Tablet and eReader Expert? Answer questions, earn points and help others
