My Samsung plasma tv is only around 4yrs old and suddenly started going from normal to dimmer projection, flickering between the two, is there a way to fix it or should I get a new tv
I have seen this in Samsung sets before, the flickering is likely a jumper in the power supply that needs to be removed, they had this issue on a number of sets---a jumper in the power supply (that board) likely is causing this, someone else here did post the location but search the model number with google for flickering and you may find it, it was widespread and as a last resort call Samsung or even a authorized service center.
I hope this helps and if you want (I spend a lot of time and effort answering questions here and if you get me the full model number I will research it when I get a chance, answer about 600 questions here a week.
Google the model number with "flickering" and I bet you can find a lot of info.
Happy holidays, Temp here is 11 degrees F right now but warm now inside the house.
