Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
hassan_at5 ???????? Posted on Dec 07, 2013
Clean unabel 46 - Brother DCP 165C Compact Color Inkjet Multifunction Printer
NerdService.Net
Level 1:
Habit-Forming:
New Friend:
  • Contributor 9 Answers
  • Posted on Dec 28, 2014
 NerdService.Net
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
9
Questions
0
Helped
2676
Points
10
Replace the ink absorber and flushing box and reset their counters
2answers
Unabel to print 72
This is a hardware issue, you may need to bring this into an authorised Brother service center for repair
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
63helpful
3answers
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
60helpful
6answers
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . [email protected]
My all in one mfc-210 keeps saying unabel to clean
This means that it has reached its limit of cleanings. There is a sponge in this machine that need to be replaced and need to reset the counter.
Check the brother website to find an authorized service center
9helpful
2helpful
Clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
50helpful
11answers
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- ready to print
Norman Weimar
Norman Weimar
k24674
