The freezer freezes, we changed the thermostat and defrost timer, but after running for about 11 hours the alarm went off again
SOURCE: Freezer will not freeze except when using fast freeze
the electronic controller is faulty,make sure you have been supllied a freezer stat and not a refrigerator stat..
SOURCE: Traulsen URS36DT:
checking a def system is kind of easy. if you have located the defrost timer just turn the little knob on the timer until the unit shuts off, shortly you should hear "hissing and pooping" from water dropping on the heater. this lets you know that the defrost thermostat is good. if you dont hear this noise check your def thermostat and heater for continuity. if you put it into def and the heater comes on then you have a bad timer..
SOURCE: Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
