I don't remember my default password for my safemark systems safe and all of our kids important documents are inside please help us
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
SOURCE: Sentry Fireproof Safe #1100 Lost Key
no if you turn your lock box around so your key is facing away from you and place your right hand on the side top and your left hand on the box and push the lid to the right a good inch and a half and lift the box will open no problem key or no key. this is a very poorly made safe
Here is a
simple way to access Windows XP with Administrator rights and privileges if you
have password protected your User account on your Windows XP system and can't
remember the password(s) to login. Whenever Windows XP is installed on a
system, it creates a default account called "Administrator" and by
default this account is not password protected. Therefore, if you bought a
brand name computer (such as Dell, HP, Compaq or Sony)or you have installed
Windows XP yourself. You should be able to login to the computer through the
unprotected.
You can log on as an administrator to assign a
new password to your account. To do this, try Method 1.
Method
1:
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button
after you switch on until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Click through several self-explanatory
screens until your reach the familiar 'Welcome' screen.
Note that
this welcome screen is limited to 256 colors and 640x480 resolution because the
primary graphics will have been set to the Windows Safe Mode software VGA
adapter. You will not be able to change this mode even in Display options,
while Windows is running in Safe Mode.
Find
the icon for the Administrator user. If the default settings of your system
haven't been changed, there should be no password for this account.
Continue on
to the User Settings control panel. Here you can change any of the other
passwords for user on the machine. Make any changes you want.
Reboot your
computer. As
long as you don't press any keys (e.g. F8) during the boot-up the computer will
startup normally.
If Method 1 is unsuccessful try Method 2.
Method 2: Reset Windows Password with SmartKey Windows Password Recovery.
Download SmartKey Windows Password
Recovery from SmartKey Password Recovery Official site
Decompress the SmartKey Windows
Password Recovery and note that there is an.ISO image file. Burn the image file onto a blank CD with
the burner.
Insert the newly created CD into
the locked computer and re-boot it from the CD drive.
Boot the PC with the CD Rom and Run the SmartKey, a window pop up with all your account names(if you have several accounts) select one of the accounts that you have forgotten its password to reset it. Just one press, you have removed the password.
Here is a
unprotected.
Method
1:
Note that
Find
Continue on
Reboot your
computer. As
startup normally.
Password Recovery from SmartKey Password Recovery Official site
the burner.
Here is a
unprotected.
Method
1:
Note that
Find
the icon for the Administrator user. If the default settings of your system haven't
Continue on to the User Settings control panel. Here you can change any
of the other passwords for user on the machine. Make any changes you want.
Reboot your computer. As long as you don't
computer will startup normally.
Here is a
unprotected.
Method
1:
Note that
Find
Continue on
Reboot your
computer. As
startup normally.
the burner.
Here is a
Windows XP yourself. You should be able to login to the computer through theunprotected
Administrator account.
Method
1:
Note that
Find
Continue on
Reboot your
computer. As
startup normally.
Here is a
Method
1:
Note that
Find
Continue on
Reboot your
computer. As
startup normally.
the burner.
If you have password protected your User account on your Windows XP system and can't remember the password(s) to Login. Whenever Windows XP is installed on a system, it creates a default account called "Administrator" and by default this account is not password protected. Therefore, if you bought a brand name computer (such as Dell, HP, Compaq or Sony)or you have installed Windows XP yourself. You should be able to Login to the computer through the Admin account.
Method One
Reboot your machine.
Press F8 before the Windows boot screen appears. Do not press F5 as used on the NT/9x ser of Windows. You will be be prompted with a boot options menu.
Select the Start Windows in Safe Mode option.
Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
The Safe Mode Welcome screen might display some of the other users on your system.
Login as the admin.
Press Yes at the prompt asking if you would like to continue using Safe Mode.
Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
Reboot your computer. As long as you don't press any keys (e.g. F8) during the boot-up the computer will startup normally.
Login as the user for which you set the password.
If the above doesn
