First, figure out what CAUSED the problem. Often times, when Windows is
rendered unbootable, there is a good reason. This can often be due to
hardware failure (bad hard disk, memory or CPU for example). In these
cases, the system repair function will not work. System repair will
only repair your software.
I
strongly recommend you run a disk utility on your hard
drive before performing a system repair. You can find more information
about disk utilities here:
http://www.techspot.com/vb/showthrea...&threadid=7602
Memory can also cause these problems. A good memory test can be found here:
http://www.memtest.orgpls rate 4 stars
