Battery has been stored for 2 years and when charging battery the red light is flashing not static, does this mean it is charging correctly? thanks
No this is not correct. If the battery is ok, the red LED should be on constantly, during charging. When toy light goes out the battery should be charged. Can take up to 5 hours.
I think on or more cells in the battery are not well. Please try to remove the battery and after a little while try charging it again. When flashing repeat this a few times. But if it does not change, you have to buy a new battery. Take care before purchasing, because the battery could cost more than a new camera..
When you say the battery has been stored for two years, I hope you removed it from the camera before storing it. Otherwise, the terminals may have corroded and damaged more than the battery. If nothing is corroded have the battery checked. Sitting unused for that length of time may have shortened the battery's lifetime considerably.
SOURCE: when i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
