Contact the authorized service center for Sony, to buy a genuine inverter board. If you wish to get some details, check the site linked here. Pull up older posts.
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
SOURCE: slow moving image sony bravia KDL32M3000
Hello darwin_gabou, My names Dave! You have a bad A/V input board.
Part #: A-1376-788-A
Link to part: http://www.shopjimmy.com/catalog/product/view/id/169673/s/sony-a-1376-788-a-bm-board-for-kdl-32m3000/
Please feel free to contact me if you have any question. I'll be more then happy to answer any questions you may have!
Dave
503-432-9904
Premium TV Tech
www.pleasefixitdave.com
[email protected]
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
