Question about Kocaso M1050 10.1" Android Tablet PC with 1GB RAM, 4GB Storage & HDMI
My tablet was turned off during a house move after charging fully and pressing settings to get to wifi connection, setting will not come up a message says "unfortunately settings has stopped working". Also the day and date on the tablet has reverted back to Friday, January 2010 which was on the tablet when I purchased it in Dec 2012..If I could get to settings I could get to Factory Date Reset.
    New Friend:
  • 38 Answers
Switch it on and hold the power button down until it shuts down and restarts.
Posted on Dec 07, 2013
Testimonial: "unfortunately this did not work. do you have another suggestion? I cannot connect to internet, wifi does not show on or off setting???"
6ya staff
SOURCE:
I have a brand new amazon fire 7 and am trying to set it up. First how can I see how much my tablet is powered up? And how do I connect this device to my internet?
Charge it. Press and hold the power button. If shows a battery by itself it's dead and it's not charging. If it's a battery with a lightning bolt symbol it's dead and it's charging. If it turns on, go to settings, find wifi settings, turn wifi on, find your wifi network, and enter the password for your wifi.
Aug 25, 2017 | Amazon Tablets & eReaders
How can i connect my tablet to wifi without a house that dos not have Internet access in county wexford ireland.
Are you trying to just connect to wifi to access a local network or are you trying to access the internet? If you just want to connect to a local network, maybe to access other devices on the network, you would need a router broadcasting the network that all the devices connect to. If you are only trying to get access to the internet, consider purchasing a hot spot device. It will provide cellular type service and will broadcast a wifi signal that you can connect your tablet or other devices to for internet access. Hot spots will cost you a monthly fee for the service and you will have to purchase the device itself. Another possibility is to use your cell phone as a hot spot and tether the tablet to it. Just remember whatever data you use on your tablet will be charged to your data plan on your cell phone. On my nexus 5x phone, it's fairly easy to turn on (settings, under wireless and networks select more, select tethering and portable hotspot, turn on portable wifi hotspot, set a password if you want to). Once turned on, the phone will broadcast a signal that you can connect other devices to for internet access. Some cellular providers don't allow tethering. If that is the case with yours there are some apps that will still allow you to set up tethering such as AndroidTethering or Easy Tether. In the past, I've had some trouble connecting wirelessly using the apps and found that using USB tether options worked better for me.
Aug 11, 2017 | Tablets & eReaders
How do I determine if I need to update my Kindle Fire?
Your Kindle Fire needs to be fully charged and connected to a Wi-Fi network before you can download the software update.
Tap the Quick Settings icon, and then tap Sync. The software update automatically downloads in the background, and installs after the download is complete and the device is asleep. Your Kindle Fire will restart during the software update.
Apr 16, 2016 | Tablets & eReaders
Tablet keeps turning off while in use. Fully charged
Go into your settings and take it out of sleep or auto shut down mode.press the helpful button
Android Tablets Power Off and Sleep Options
Jan 26, 2016 | Visual Land Connect 9" Android Tablet...
How do I get the message unfortunately com.android.phone off my sons proscan tablet?
Have you tried the reset with the paper clip in the reset hole yet.?
I think the reset hole is on the back. Press gently into the hole with a paper clip.
You will lose all data however and it will go back to factory default settings.
This is a common problem with Proscan tablets. Make sure you charge the battery fully before starting.
Jan 08, 2015 | Tablets & eReaders
How do i set up a rca tablet
1. Charge it until it is fully charged.
2. Turn it on.
3. Connect it to your home wireless (WiFi) network as per the instructions in the set up guide that came with the tablet.
4. Start using it to get to know what you can use it for.
Dec 28, 2014 | Tablets & eReaders
How do I reset my Lenovo tablet
You did not say which tablet you have. For Ideatab Android tablet, start with battery fully charged and tablet OFF. Press and hold Volume Up and Power at the same time until menu appears on screen. To navigate the menu, use Volume Down to move through the menu choices, Volume Up to select the current menu choice (like an Enter key) and Power button to return to previous menu. On the "Factory Menu", move down to "Clear eMMC" and select that option. You should see a message that data is being cleared. This may take several minutes to complete. Wait for it. When it completes, the tablet should be reset to the way it came from the factory so you will have to set up again user ids, wifi passwords, download apps, etc.
Dec 23, 2014 | Lenovo Tablets & eReaders
Meep will not connet to wifi
Here is the remedy for that error:
We've heard a few reports of Wifi connectivity issues recently, among them 'Authentication error'. If you receive this message, our recommended remedy is to remove all Wifi connection information from your Meep, turn off your Meep, reboot your router, then turn on your Meep and re-add the Wifi information. Follow these steps exactly in this order to resolve this error message:
1. Remove all Wifi network information from the Meep's settings
2. Reboot your router
3. Re-add the Wifi network information to the Meep's settings
4. Reboot the Meep.
Jan 01, 2014 | Oregon Scientific MEEP Kids Tablet
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
Jun 05, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
I received a kindle for Christmas. It has been wonderful until last night when it stopped connecting to the Dell or whispernet wi-fi. What to do?
Something has changed in your wifi settings first check wifi is turned on (press menu On the right hand side next to the battery it will say off is wifi is turned off) the first option in the menu is turn on wifi.
if wifi is on click home -> menue and go to settings scroll down to wifi see if your wireless network is there if it is not but other networks are there it is a problem with your house network not the kindle
if your house network is there with a message next to it saying connect then click connect if it says forget then forget it and connect again.
If the device fails to connect you should go into settings push menu and then restart if still no luck go to settings and click reset to factory defaults and try again through wifi settings if this does not work their is a fault with your device and you have to talk to amazon
amazon will charge you to replace the device if you tell them anything like you dropped it so as far as you know it was working when you went to bed you woke up the next day and it didn't work ;)
let me know if this helps
Mar 11, 2011 | Amazon Kindle Wireless Reading Device
Kocaso M1050 10.1" Android Tablet PC with 1GB RAM, 4GB Storage & HDMI Logo
Top Kocaso Tablets & eReaders Experts
 Mike M
Mike M
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
