Does not feed the paper. It makes a sound as if trying to feed it through. I replaced the spring clutch and pick roller already. But still makes the clicking machine gun sound while trying to feed paper.
Right click on the ScanSnap Manager icon at the bottom right of your computer screen, go to "Scan Button Settings"
Then, go to the tab that says Paper. If you don't see it, click on details at the bottom left.
In paper, change multifeed detection to Check Length or None instead of Ultrasonic Sensor.
If this works, then the ultrasonic sensor on this scanner has failed. The only function is it detects if multiple pages go through at the same time by listening to the vibrations. Your scanner can still scan fine without it.
Hi irene
scansnap s510 drivers (win 7/8) can be found at driverupdate us . (32/64 bit)
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
The Fujitsu ScanSnap V2.2 L11 drivers have been patched by me to work with S300, S500, S510 and fi-5110EOX/2/3 PC-based scanners for the MAC. No need to buy a new scanner. Just apply the patch and then send me a Christmas card! ;)
Visually check the clutch spring (located on the left side of the pickup roller shaft, just before the gear). If the spring is deformed or broken, replace the entire pickup roller shaft. The part you need to order are shown below. You will also need a small 'C' clip. I do not know if the clip comes ith the shaft or the gear...
