Any idea if it's possible to get replacement circuit boards for a kodak hero 5.1 printer
You may choose PCB assembly what you want on https://www.raypcb.com/
SOURCE: IBM 4230 with new printer board is printing gibberish
if it prints, but it is gargabe, either the cable has a set of pins crossed or the Baud rate is incorrect on the card.
SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll
need to keep running it untill it runs clear and it uses alot of your
ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
SOURCE: kodak esp 5 not printing properly and no yellow
Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
SOURCE: HP laserjet 5550 not printing cycan. Replaced
You will not find the answer to this problem on any forum as I have searched each one! However I have had the same problem and found out that if you have reseantly replaced or reseated the Paper Pic-up assy you may have not pushed down the plastic top cover which sits directly underneath the Cyan Cartridge, this will cause your 5550/5500 to think there is no problem and carry on printing without any error messages.
I'm just a man doing a boys job, lol
Testimonial: "Wow! Thank you sir. That was the problem. I had not touched the paper input assembly. So obviously, a user did this. Thanks again!"
