SOURCE: Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
SOURCE: i NEED TO LEARN HOW TO SCAN
hi if u have installed ur printer u will have SOLUTION CENTRE,,,,find it and go from there
cheers
SOURCE: HP 5610 all-in-one "no scan options"
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&jumpid=ot_recdoc/c00503569/en_us/c00809848/loc:1&custom_solutionid=rd_c00503569&lc=en&dlc=en&cc=us&product=441125
Go here it is instructions on how to scan from Microsoft Paint. I had the exact same problem and this works!
Happy scanning!
SOURCE: Can an HP Photosmart C4180 Printer scan a document to a computer?
You should have recieved software with the printer to do this, Look in the Hewlett-packard folder in the programs menu. It might be listed as HP Director. From there you should choose scan to as the option, one of the choices should be "to Fax".
SOURCE: How do I scan a document from HP Photosmart?
Follow thes below steps to scan to PC and save it without using HP software.
WIndows XP:
1. === Scanning with Paint: ===
1. Click the Start (Windows) icon.
2. Click All Programs.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Windows Vista:
1.Click the Start (Windows) icon.
3. Click Windows Photo Gallery.
4. Click File and then click Import From Scanner or Camera.
5. Click Import.
6. Click Scan.
