Question about Broksonic CTGV-5463TCT TV
Can't view my digital channels
I cannot view any of the digital channels. I have a pair of old rabbit ears attached but it keeps saying that the digital channel signal strength is low. Do I need a converter box?
    Problem Solver:
  • 15 Answers
Get an outdoor antenna. Digital signals very rarely reach indoor antennas unless you are within ten miles of the signal origin.
Posted on May 16, 2009
6ya staff
SOURCE:
How do you connect rabbit ears to a tv
First you may need a 300 ohm to 75 ohm transformer if you have a flat wire with 2 leads coming out of the rabbit ears..you can get one at walmart, I attached a picture of what they look like...hook the 2 terminals from the rabbit ears to the transformer and plug it into the round terminal of the tv, set the tv to cable or antenna, what ever it has for settings, unfortunately though you may not get all that much with old rabbit ears as they are lower frequency pickup than the new HD channels run on.
aceb6079-dc98-4da7-926e-7d52885feaff_1.13301fb611a36dff57b92b05b4fdcbd5-j2qglkibcccvgpapoz0ib4qd-2-0.jpeg
Nov 08, 2017 | Televison & Video
Will it pick up digital air signal
It depends on how old the TV is. If manufactured after 2010 it probably will receive digital signals. You can test now by attaching a pair of rabbit ears to the antenna input and running set up to select over air channels.
May 14, 2015 | Televison & Video
I have cello TV and now no channels . have tried factory reset and still shows message as Database empty. What can you suggest?
To Get free broadcasts you will need to 1) have an antenna and 2) run the Channel Scan or Auto-TUne program. Any antenna will work - Rabbit ears etc. Once connected you need to go to setup and run the channel scan - it will find the digital channels in your area and load them into the database. You can get an antenna at Radio Shack, Meijer, Kmart etc. any place they sell TV's. Like I said even the old Rabbit Ear antennas work fine for Digital TV.
Jan 15, 2015 | Televison & Video
2 tv's. recently had uverse removed. neighbor has rabbit ears-gets local channels. I get nothing. Does something with uverse change my tv's?
Your tv my have a setting for type of input. Cable of Air channels. You would need to switch that to AIr. Also, the air channels have gone to a digital signal and I believe they take "digital rabbit ears" I think the old style may not pull in the digital signal, but I'm not entirely certain about that one. Something like this http://www.amazon.com/AmazonBasics-Ultra-Thin-Performance-Indoor-Antenna/dp/B00DIFIO8E/ref=sr_1_1?ie=UTF8&qid=1409885138&sr=8-1&keywords=digital+antenna+for+hdtv+indoor
Sep 05, 2014 | Televison & Video
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
Do I need a Set Top Box Converter?
Yes you can continue to use Rabbit ears if you are close enough to the station. Most digital stations are operationg at reduced power. Switch it to digital and let it scan for channels, you may be plesantly surprized at what it finds.
Sep 30, 2008 | Televison & Video
DTV Converter Box
If there is no digital tuner built into the tv or unless you subscribe to Cable TV or Satellite service you will still need a converter to view tv with rabbit ears (air broadcast).
I Can Fix It
Sep 22, 2008 | Protron PLTV-32 Television
Rabbit ears,vcr,dvr,tv
Connect Rabbit ear antenna to VCR, Take Audio / Video Out and connect to DVR, and Audio / Video out of DVR to AV IN of TV. Start Tuning Channels using the Tuner of the VCR, and store them. Now, whenever you wish to record a particular Channel, select that channel on your VCR, and Record on your Blank DVD in the DVR.
Jan 10, 2008 | Televison & Video
Broksonic CTGV-5463TCT TV Logo
865 people viewed this question
Top Broksonic Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
