Can't see anyway to get at the tube between base and body of machine
Hi Chris,
It's normal for your machine to become warm in use - like most Dyson vacuums, DC41 Animal will shut itself down for protection if it starts to overheat.
However, the popping sound and change in performance you've described suggest that something is blocking the machine. This is simple to resolve following our online troubleshooting checks: http://www.dyson.com/support/dc41/dc41-irspu/diagnosis-root-menu/performance-flo-area-check-dc41/flo-brushbarvid-dc41/redirect-to-performance-flo-base-dc41-checking-the-internal-hose/performance-flo-base-dc41-checking-the-internal-hose
It's also a good idea to give the filters a wash - in normal use this should be done at least once every three months, as shown in the video below. Use cold water without detergent, and allow at least 24 hours for the filters to dry completely before replacing them.
If you'd like further advice after you've given this a try, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
SOURCE: Dyson Animal-suction loss
Had the same problem twice and washed the filter to no avail. Called Dyson to troubleshoot, and in one minute they had me removing the purple plastic noodle shaped piece towards the bottom on the side (the next time it was the silver noodle on the opposite side). Inside was a bent pen and tons of debris wrapped around it that slowed the suction. Poked the debris out, and it worked perfectly.
SOURCE: suction loss on dyson animal
Hi.
Keep the axe on hold try this first.
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
SOURCE: Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
SOURCE: dyson dc07 animal\ no suction
There could be a few things that would cause your Dyson to have no suction. I will give
you detailed step by step instructions along with pictures on how you can
diagnose this.
Possible Problem
#1. The first problem is extremely common. In fact, we probably see
between 2-3 of these problems every week. It mostly happens after people
take the bottom plate off the vacuum in order to clean the roller brush. What happens
is when they reinstall the bottom plate, they put it on on
incorrectly. It's actually very easy to do. When the bottom plate
(soleplate) is installed wrong, there will be a gap between the bottom plate,
and the agitator housing, or the purple tray the roller brush sits in. This will cause the
soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to
the user that vacuum has lost suction power because without the brushes hitting
the carpet, the machine will not pick up very well on floors, but when they use the
attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in
between the two housings:
Here's another picture, that is the RIGHT way to install
the soleplate:
I would say probably 6 times
out of 10 this is the problem with the customers machine. If you checked the
soleplate and it is installed correctly, move on to the second possible
problem.
Possible Problem # 2. Turn the
vacuum cleaner upside down so the brush roller is facing upwards. I found the
easiest way to work on it is to put it on a counter top or work bench. On the
left hand side behind the roller brush you should see a flexible transparent
hose that goes from the motor to the agitator housing. This hose actually
has a lot of strain on it when the vacuum cleaner is in the reclined position.
When the first few series of Dyson DC07 models came out, they didn't make this
hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually
right where the end of the hose that goes into the agitator housing. Examine your
hose and see if you have any visible cracks in this hose. If you need to you may
just remove the entire hose assembly by pulling on it. It will easily come right
out of the machine so you can inspect it better. Here's a picture of where the hose
usually cracks:
This would
also explain why the vacuum works fine when using the attachments, but not on
the floors. The attachment hose uses a different suction channel, and when the
machine is in the upright position, no suction goes through this hose. If you do
find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part #
904219
Possible Problem #3.
I would suspect that this may not be the problem, but if neither of the
solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added
there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction
port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for
you, try this last one. The Dyson DC07
models use a clutch mechanism that stops the roller brush from spinning when
changed from carpet mode to bare floor mode. This clutch mechanism is a notorious
problem with all Dyson models, in fact they were such a problem that Dyson
had to redesign the DC07 model to a non-clutch system. Even if yours is one of
the newer ones that don't use a clutch, yours still has a belt inside. You can
tell if your model uses a clutch or not by the shape of the roller brush. If
your brush is a perfect cylinder shape, yours does NOT have a clutch. To check
and see if the clutch or the belt have gone bad, first release the handle on the
vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet
mode. Now while the handle has been released, turn the machine upside down and
see if the brushes are spinning. If the brushes are spinning then turn the
vacuum right side up and put the brushes on the floor. Can you still hear the
brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your
brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to
you, please be sure to rate this repair as helpful by clicking the thumbs up
icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
SOURCE: A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
