Asko W6221 Front Load Washer Logo
k
kenny Posted on Dec 08, 2013
Open door tool w6903 - Asko W6221 Front Load Washer
How to diagnose which door is causing the door ajar warning on dic for 08 pontiac g6 4cyl 4dr
It should tell you which one .
Driver Door Ajar Malfunction
Passenger Door Ajar Malfunction
If not a scan tool would be the best way.
Ignition ON, observe the scan tool Driver Door Ajar Sw parameter while opening and closing the driver door. The parameter should change between Door Closed and Door Ajar
? If the parameter does not change, refer to Driver Door Ajar Malfunction.
With the passenger doors closed, observe the scan tool Door Ajar Switch parameter while opening and closing each door. The parameter should change between Door Closed and Door Ajar.
? If the parameter does not change, refer to Passenger Door Ajar Malfunction
Ignition OFF, disconnect the harness connector at the driver door latch.
Test for less than 5 ohms between the ground circuit terminal 8 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify the scan tool Driver Door Ajar Sw parameter is Door Closed.
? If not the specified value, test the signal circuit terminal 6 for a short to ground. If the circuit tests normal, replace the BCM.
Install a 3A fused jumper wire between the signal circuit terminal 6 and the ground circuit terminal 8. Verify the scan tool Driver Door Ajar Sw parameter is Door Ajar.
? If not the specified value, test the signal circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the BCM.
If all circuits test normal, test or replace the driver door latch
My 06 sentra driver door won't open from outside or inside so i can't take door panel out unless i open the door please help
Idea - open up the passenger side door and see how the locking mechanism works. Then with a coat hanger devise a tool to open the door.
Then using same tool apply same technique to driver side door to open and repair.
How do you take the door panel off 2011Kia Sorento
You will have to get the door open first and then remove the fasteners etc to release the panel from the door. If you cannot open it from the inside or the outside you will need to use a jimmy tool to hook onto the door lock mechanism inside the door to open it. If you do not have a tool usually CAA/AAA etc or a garage can do this for you.
Mercedes E420 dead battery. Doors wont open
if doors are locked go get a mechanical door tool to open from outside.. parts store rents these..or use a coathangar bent to reach the door lock or call the police to unlock your car.. they carry the same tool and will open your door with proof of ownership..
ASKO W6903 Firmware
This should not be possible at all! What happends with the machine now?
ASKO W6903 spin cycle not getting to speed
Again it could be the carbon brushes or a faulty motor tacho
hope this helps
Lost manual
yes directly from asko online
Top Asko Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
