The left side of the door is about a 1/4" from completely closing. I can press against it and it will shut, but then immediately slides away again. And it just enough that some air seeps in, causing a buildup of frost inside. Any ideas how to get the drawer to slide all the way in and stay?
SOURCE: sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
SOURCE: Bottom freezer drawer doesn't slide out easily, frost builds up
3M spray silicone lubricant in 24 oz cans is good down to -23 degrees and FDA approved for being around food. Works a treat.
