I have the same model Miele and ordered a replacement part. I have 2 Miele ovens side by side, and a door hinge on both ovens began to malfunction. I ordered and received the hinge , but when I started to install it, I found that the hinges were fine! The issue was that the 3 screws that hold the hinges to the oven frame came loose. One of them had fallen out on each of the doors, they had to be jiggled in order to close properly, which was not satisfactory. The ovens were installed 13 years ago by the original owners.
You will need to slide the oven out of its enclosed space and unscrew the sheet metal siding in order to gain access so that you can unhook the coil spring attached to hinge. I found that one of the small machine screws has fallen out on the 2 malfunctioning hinges. Once the spring is unhooked, you can align the hinge to screw it back in, and tighten the other screws that hold the door hinges. The screws on the other side has also become loose.
installation dimensions are included on the brochure of the unit
the brochure will be available from a retailer or on line and those dimensions are what builders use to make the right sized opening
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
Installing an LG over-the-range microwave is an excellent way to save space in your kitchen. These types of microwaves are ideal for smaller kitchen areas. Although the retailer where you purchase your over-the-range microwave will likely offer installation service, rest assured that you can install the microwave on your own. How to Install an LG Over the Range Microwave eHow
You are going to need a display kit to fix this. It comes with a new display and relay board. The kit is about $200 and is somewhat difficult to install. This repair altogether usually runs about $400 to fix if you dont have someone handy that can do it for you. It involves removing and replacing at least 20 wires from the relay boards, as well as either pulling the oven from the wall or working in a tight space to change the board. You may be able to find just the display board somewhere, and that is very easy to install, but I've only ever gotten the part as a kit. Hate to be the bearer of bad news. Good Luck!
