SOURCE: need unlock code for lg ks360 mobile phone
Hi Friend,
Kindly follow the instructions in the below mentioned link and you can find by your own the unlock code
http://www.pb4kn.co.uk/ks360_unlocking.htm
If this is helpful and solved your problem kindly rate this
Thanks for using Fixya
Regards,
Ayyasam
SOURCE: T-mobile LG Android phone At&t SIMs Card need network unlock code
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.For details to obtain the PUK code for the SIM card, pleaseclick on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Warning : Do not enter
any wrong unlock codes on your LG GR500 Xenon mobile phones. If you
enter over a certain amount of wrong unlock codes on your LG GR500 Xenon
mobile phone, your phone may get hard locked and sometimes become
unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
If you are trying to use a SIM card in your phone and getting a message like
"Enter Subsidy Code", "Incorrect SIM Card", "SIM not
provisioned" or similar messages, then you need an unlock code for your
mobile phone. You can get LG 620GM Unlock Code from the network provider, they will verify the account holder
information. They can open up all networks for you where you want to use your phone. You can check LG Unlock Code site, they will
provide you an accurate code fast for the lowest price with easy to follow instructions on how to unlock your phone. Once your phone is unlock, it will work with any networks worldwide without sticking to one network.
Hope is helps.
Thanks.
