LG KG800 Cellular Phone Logo
Posted on May 12, 2009
GPRS setting required for LG KG200. Unable to connect GPRS/MMS on LG KG200 mobile phone with BSNL prepaid connection.As per the setting downloaded from BSNL's site it shows "Please refer your Handset Manual to apply these setting." Please help.
  • Anonymous May 23, 2009
    gprs activated dut no settings
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on May 12, 2009
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
7559
Points
97
Plz ask bsnl customer care to activate the gprs
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1316
Points
6
Go to http://bsnl.co.in/service/mobile_gprswap.htm
Scroll down & click on CLICK HERE TO DOWNLOAD GPRS/MMS/WAP setting
you will be taken to service portal - here select your state and follow on screen instructions your problem will be solved
good luck
3helpful
2answers
GPRS Problem in my handset nokia2630, bsnl prepaid. I save message sent by bsnl. G is coming and sometimes E is coming at left of Set. When I try to connect gprs it shows subscribe packet data first. This...
hi....
think you didnt select your BSNL settings as default setting ,so only your getting as 'subscribe to packet data first'.
As you said it says 'only 20 sets are allowed', there are plenty GPRS settings present in your mobile.please go to default configuration settings and delete all the settings which you previously stored in it.
Now call your BSNL and ask them for the GPRS settings they wil send GPRS setting and MMS settings also. please save it and make it as default settings.Then you can start using the GPRS connection.
If you didnt select it as default setting,follow the below steps to set it,
please follow the steps down to set your BSNL setings as default.
Menu--->Settings---->Configuration---->Default configuration settings.
open this menu and select BSNL as your default service provider,
Then you can start using your GPRS.
Thanx
1helpful
BSNL GPRS - packet data connecttion not available
You can set your gprs setting manually go to access point and set gprs gprsnorth.cellone.in
2helpful
2answers
LG KS360
Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL http://live.vodafone.com
- GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address http://pxt.vodafone.net.nz/pxtsend
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
2answers
No gprs settings from bsnl customer care for N73
hey there! thanks for using Fixya.com!!
I suggest that you should go to their office to set it manually. If they can't able to send you the over-the-air settings. Nokia N73 is GPRS capable, but I think it should be done manually.
Thanks & Regards!
8helpful
2answers
How to start internet on the samsung sghl 700 mobile gprs setting of prepaid cell(bsnl) sim
How we can connect SGH L-700 MOBILE with bsnl gprs in my computer.
D C DIXIT
LUCKNOW
3helpful
2answers
Manual application to apply for port, wap, gprs, mms in blackberry 8800
Try this :
Go to your phone MENU -> CONNECTIVITY-> BSNL GPRS
or
MENU -> CONNECTIVITY-> BNSL PREPAID SERVICES ->GPRS SETTINGS.
GPRS and MMS SETTINGS will be send to your phone shortly, along with the instructions on how to install. Goodluck......a rate from you for this solution will be much appreciated. Thank you!
Lg kg200 gprs connection
lg kg200 requires ip adds,
call c care to know the adds.
try this no
202.056.231.117
Apr 01, 2008 • Cell Phones
2answers
Help for setting gprs on my lg kg200 dynamite
have a problem in my lg kg200 dynamite that i does not use my mobile for wap and mms please solve my problems
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
