How do i change battery on my sony nwz-x 1060
SOURCE: how to replace battery on sony mp3 NWZ-A726
Download this service manual from deposit files
SERVICE MANUAL
Then goto page 6 you will find the distructions there make sure you keep the screws in a magnetic dish they are easy to loose !!
LOL
SOURCE: nwz x1060 earphone socket faulty
This type of problem is quite common. The fault is usually a dry or weak solder joint on the ear phone socket on the circuit board.
This can be repaired by removing the circuit board from the player to get access to this socket and resoldering the phone socket connections.
I suggest you use a fine tip soldering iron. If you do not think you can DIY then ask a savy friend or take it to an electronic repair shop.
