Tablets & eReaders Logo
A
Anonymous Posted on Dec 09, 2013
Remove baidu from iPad - Tablets & eReaders
Olli Halvari
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 16, 2016
Olli Halvari
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
281
Points
Have you installed a Baidu app on your iPad and wanna remove it?
Well, the first method recommended for you is to directly delete apps from Home screen on your iPad.
1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
Sometimes you cannot see the X and don't know how to delete apps on iPad directly, you can check the Settings at this moment. Then you can try to delete the apps on your iPad again.
1. Check the "Settings", then scroll down a bit and tap on the "General" option.
2. Tap on "Usage" (older version of iOS) or tap on the "Storage & iCloud Usage" (newer version of iOS).
3. You need to tap on "Manage Storage" and you'll see a list of all app installed on your iPad. Simply select the app and tap on "Delete" to delete that app.
There are also some other methods to help you remove unwanted apps from your iOS device. Click the following link to know more.
How to Delete Apps from iPad
I cannot open any search engines.
  1. Google. Google Search Engine is the best search engine in the world and it is also one of the most popular products from Google. ...
  2. Bing. Bing is Microsoft's answer to Google and it was launched in 2009. ...
  3. Yahoo. ...
  4. Baidu. ...
  5. AOL..
  6. Excite. ...
  7. DuckDuckGo.
tip
How to Remove Songs from iPad in 3 Ways
Part 1. Delete Individual Songs from iPad
Step 1. Launch the Music app on your iPad.
Step 2. Tap "Songs" on the bottom to see all of the music on the device. Choose the individual track you want to delete and slide your finger to the left across the songs.
Step 3. Tap on the red "Delete" button to remove music from your iPad.
Part 2. Delete All Songs from iPad
Step 1. Go to the iPad's homepage and tap on "Settings" icon.
Step 2. Tap "General" > Select "Usage" > Choose "Music." The iPad will display how much space is taken up by music on your device.
Step 3. Tap "Edit" button on the top-right > Tap the red icon next to All Music > Tap on "Delete" to remove all songs from iPad.
Part 3. Delete Selected Songs from iPad with AnyTrans
AnyTrans is an all-around iOS files manager that made to transfer and manage all your iPhone, iPad, and iPod content, such as, music, videos, photos, contacts, notes, messages, apps, etc. You can freely add or delete songs from your iPad with AnyTrans.
Step 1. Download and install AnyTrans on your computer. Run it, and connect your iPad to computer.
Step 2. On the homepage of AnyTrans > Click "Audio" > Select "Music".
Step 3. Highlight the songs you want to delete and click the trash icon on the top-right of this window to delete the unwanted songs.
Resource from: How to Delete Music from iPad
How to Delete Music from iPad in Three Ways
I need to get rid of my passcode on my ipad 9.7 pro and my iphone 7plus i need help asap thank you
You can remove passcode from iPad by restoring your device with iTunes.
Step 1. If you've matched up your iPad with iTunes, you can reestablish your device.
Step 2. Associate your gadget to the PC you matched up with.
Step 3. Open iTunes. On the off chance that requested a password, attempt another PC you've synchronized with, or utilize recuperation mode.
Sit tight for iTunes to match up your iPad and make reinforcement.
Once the synchronization and reinforcement have finished, click Restore. After clicking Restore, you have successfully remove iPad passcode with iTunes.
How to Remove Passcode from iPhone
My iPads storage is almost full withphotos. I would like to delete some, but no dust bin icon appears, and a message tells me that it is not possible to edit them. What do I do ?
If you can't deleted photos on your iPad directly, perhaps you can try a 3rd party iPad data manager program on your computer. The tool will help you transfer, add and remove photos.
How Can Remove Photos from iPad in Batch
Cannot open ipad asking for a pass code and says ipad has not been updated
You can try the default password or just remove the password. Follow below steps to do that.
Generally, the default passcode can be 1234 or 123456, and the digits rely on the blank number.
If this won't work, try below method.
When you find "iPad asking for passcode I never set", it is sensible for you to remove iPad passcode by restoring iPad with iTunes. The precondition is that you have backed up your iPad to iTunes before you forgot the passcode. Now let's begin to see how to get this work done.
1. Run the latest version of iTunes on your computer and then make sure that you do not connect your iPad with your computer.
2. For iPad with Face ID, you need to press and hold the top button or the volume button till you see the slider of power off shows up on the screen. Drag the slider from left to right to turn off your iPad. After that, plug your iPad into computer while holding the top button. You need to hold it until the recovery-mode screen appears.
For iPad with home button, you need to press and hold the slide or top button till you see the power off slider interface. Drag the slider from left to right to turn off your iPad. Afterwards, you need to insert your iPad into computer with proper USB cable while holding the home button. You need to hold the button until the recovery-mode screen displays.
3. In the interface of iTunes, you will see a dialogue for you to restore or update, you need to choose the option of "Restore" in the panel. Thus, iTunes will download program for your iPad. You need to wait for over 15 minutes until your iPad exit the recovery mode. Thus, you need to repeat steps 2-4.
4. Wait for the end of the procedure to set up and use your iPad without a passcode.
The process to remove iPad passcode via restoring iPad with iTunes is not so hard for you at all. You can give it a go to help you to pass through the passcode inquiry simply.
For more details, check: Fixed: iPad Asking for Passcode I Never Set
How do I delete music from my ipad
Method 1. How to Delete Individual Songs from iPad
Get another two ways in this guide: https://www.imobie.com/support/delete-music-from-ipad.htm
How do I take apps of my iPad
On your iPad you are only able to remove the third-party apps that you have installed. You will not be able to remove the apps that came pre-installed with your iPad firmware, although you are able to move them around and to other pages.
To remove a third-party app, press and hold the app icon until it begins to shake, you will a small "x" on the top corner, pressing that "x" will bring a pop-up that will ask you to confirm the deletion of the app.
4helpful
3answers
Delete photos from my apple ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to remove the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to remove from the iPad under the Sync Photos from heading.
5.If you want to remove all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
More detailed guide about how to delete photos from iPad.
www.iphone-mac.com/how-to-delete-photos-from-ipad-camera-roll.html
2helpful
4answers
How do you remove books from an iPad
Hey , three steps are enough
Step1: Open the Kindle app on your iPhone
Step2: Tap and hold the book you need to delete.
Step3: Tap the pop-up "Remove from device" to remove the book.
more ways to remove books permanently. check this guide out!
How to Delete Kindle Books from iPad or Kindle Cloud
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
