Question about Zebra Z4Mplus Label Printer
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
I have a problem with Z4M PLUS. It doesn't recognize the starting point of the MEDIA(LABEL). In our company(SK Hynix) changes the several size of MEDIA(LABEL) often with one PRINTER. It is fine when I print MEDIA(label) with ZM400 printer, but with Z4M PLUS, it is printed on 1.4 inches below. I think Z4M PLUS doesn't recognize the starting point of MEDIA(Label) automatically when the MEDIA(LABEL) is changed. I think it is because of the 'WEB. S', 'MEDIA S', 'MEDIA LED'. How can I make it automatically well like ZM400? Please help. I need appropriate printer setting.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Zebra Expert
  • 142 Answers
You should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Posted on Dec 09, 2013
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Zebra 105sl - printer does not print correct size
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
Posted on May 19, 2008
Anonymous
  • 31 Answers
SOURCE: Zebra 105SL label issues
I am surprised that you are using that sequence of buttons to solve this problem. I am pretty sure that they want you to go into the "Media Sensor Calibration" setup in the config menu. It is a bit more complicated than what you have described. I also believe that the size of the gap on two of your labels might be out of tolerance (they are usually 1/8" gaps between the labels). The black marks are a problem for the transmissive sensors. You may need to move the transmissive media gap sensor (remember it has two parts: upper and lower). I would usually setup mine for a place beyond the black mark so that you are looking at just the white paper.
To start out:
1. Load the backing of a 6" strip of media (no label attached).
2. Remove a ribbon (if you usually use one).
3. Close the printhead.
4. Press SETUP/EXIT and then NEXT/SAVE until "Media and Ribbon Calibrate" appears.
5. Press "+" to start the calibration procedure. You should see the "Load Backing" in the LCD Display. You already have the backing loaded so continue to the next step.
6. Press "+" to answer the message and the next screen should say, "Remove Ribbon". You have also removed the ribbon.
7. Press the "+" to continue. You should see the screen say, "Calibrating Please Wait". After the sensors are setup by the machine a new screen should appear, "Reload All".
8. Open the printhead, and move the labels until they are loaded correctly to print. Smooth out the ribbon and load it correctly.
9. Withe media and ribbon now loaded, press "+" to continue and the machine should say, "Media and Ribbon Calibrate".
10. Press the Setup/Exit button once. It should say, "Save Changes Permanent". Press Next/Save to finish the process.
11. Do a normal calibration of your stock and print a label.
You are done. The machine will run for the labels you have setup the sensors for. Unfortunately, you must do this for each of the media types. To automate this, you could run a Configuration listing, capture the settings you just created for each type of label. Take these to a programmer to have them send the setup to the machine before the job. This is beyond the scope of this type support to really help you.
Posted on May 29, 2009
Bob Miller
  • 97 Answers
SOURCE: Zebra LP 2844 doesn't feed label all the way out
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
Posted on May 06, 2010
My Zebra Z4M Plus printer is printing, but some part of the label is missing. The printing is good, and starting from a certain point, nothing is printed. There is a straight line (approximately 2cm from...
if is line across all the label, need printhead replacement, but first clian the printhead and the rollar, then check if the length and the with is the correct from the driver, last solution, resect the printer to factory defult.
Nov 04, 2010 | Zebra Z4Mplus Label Printer
My Zebra Z4m plus start to print in middle of the label,but suddenly to appear next message. error de papel.and stop the machine and the print on the label is in wrong positions
The label is not calibrated. Press keys FEED, PAUSE and CANCEL, turn the printer and release the keys when making the labels. Also verify that the type of material is NOT CONTINUOUS.
Roberto Martinez
Sep 28, 2009 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus won't calibrate 2" Circle Labels
try to set the printer to the factory default setting
Aug 13, 2009 | Zebra Z4M Printer
Password
The default password is 1234
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Unable to align printer to start at top of a new label; where can I download a manual for this printer (Z4M plus) thank you - barry
Put in a new roll of labels. Calibrate the printer. Make sure the program you are using is set for the size label you are using. If it calibrates properly, you should end up with the tear off perforation at the edge of the feed out area.
Jan 28, 2009 | Zebra Z4Mplus Label Printer
(zebra Z4M PLUS)
Here is a website to help with specs and supplies...
CLICK HERE
Nov 27, 2008 | Zebra Z4Mplus Label Printer
NO COMMUNICATION
hi i have zebra z4m plus printer when i give them command for printing it's not printing and i need a solution can you please help me thankyou
Apr 10, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
205 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
