Question about HTC Touch HD Smartphone
My HTC Touch HD touchscreen does not allow to input pin
When phone is turned on i have a personal pin to input via touchscreen this will not accept any input so cannot use phone, tried rest button reboots and still asks for pin thaty cannot be input, any suggestions greatly appreciated. Thanks Matt
    President:
  • HTC Master
  • 782 Answers
Hi Matt, Is your touchscreen not responding? Try put your sim to other phone and disabble pin.
Posted on May 12, 2009
I had the same problem two times i solved in the past but i forgot how now i bought a new htc hd and two months trying to change the input mthod going to setting-input and change it never worked look open a message to respond in the bottle (down ) in the keyboard you ll find a little square and beside a little arrow click there and easy done change your input method trust me i prooved all even i bought a little program to do it and never worked just do that and enjoy it
aztecamayor@hotmail.com
Posted on Jul 08, 2009
Anonymous
SOURCE:
Forgot pin code how to unlocked screen lenovo A5600
You have to do a Factory Reset. Warning! This will erase all your personal settings!
Hard Reset LENOVO A5600
First of all, turn off the phone by using the Power key.
In the next step press and hold together the Volume Up and Power button for a couple of seconds.
You should release the Power key as soon as you see the LENOVO logo on the screen.
When the Recovery Mode pops up let go of the Volume Up button.
Next, choose "wipe data/factory reset" by using volume key and use the Power key to confirm your choice.
Afterwards choose "yes" from the menu, and accept it with Power button.
The samrtphone is erasing all personal data and customized settings.
Finally, accept option "reboot system now"
Good job! The factory reset is done! Now you can activate your phone.
Dec 06, 2017 | Lenovo Cell Phones
What do I do to fix my phone? After I turn it on it freezes and doesn't allow me to do or open anything.
Last option that you can do is to hard reset the phone, please take note that this procedure will delete everything on the phone. Please follow steps below:
  1. Turn OFF the device completely.
  2. In the same time, press and hold Power button, Home button and Volume Up button for several seconds.
  3. Release Power button only when Samsung logo appear on the screen.
  4. Release the rest button when Android logo appear, the recovery menu will appear.
  5. Choose "Wipe Data / Factory Reset" option using Volume button and Power button to select it.
  6. Choose "Yes - delete all user data" to confirm the whole operation.
  7. Select "Reboot System Now" when it has complete.
Aug 19, 2016 | Samsung Galaxy Centura SCH-S738C...
My kyocera rise touchscreen blank but keyboard lights up when power button pushed what is wrong
Faulty lcd , physical damage or possibly but not likely disconnected from motherboard . The buttons normally run off a different circuit and will work however it would appear the display has failed you could DIY or repair shop but check the price and if you're not confident about DIY , DDIY , don't do it yourself :-)
Nov 27, 2014 | Kyocera Cell Phones
Samsung gt i5503 touchscreen not responsive
Step by Step Follow The Tricks
hard rest without touching the screen
1. REMOVE BATTERY & PUT IT BACK
2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON)
3. WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE)
4.IT WILL POP UP WITH HARD RESET MENU
5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON
6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON
7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON
TESTED 1000% WORKING
May 18, 2012 | Cell Phones
Screen freezing touch screen not working samsung pixon
The problem is a faulty contact from the touchscreen leading to the phone board.
On the right side of the phone were the volume buttons are, under the touchscreen is the screen's contact. Try "detaching the screen's face a little from the phone body exactly at the volume down button(using your fingernail or something) and see if the touchscreen is responding in anyway. Now try to pull a little bit the touchscreen frame from the rest of the chassis and see if it works.
Be careful though not to totally destroy your phone...
Jun 28, 2011 | Lands Phones
Give me formate code for samsung C5212
list of samsung codes for u
Quote:
PLEASE BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong
network SIM and insert a half of it,(pic2501)
so it won't ask for
network password and shows "Insert SIM" message.(pic sam25020)
Now put the battery ,and switch the phone on .(phone shows "InsertSIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone isstill asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#(star7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable
networklock By typing: #7465625*638*00000000#(hash 7465625 star 638 star8zeros hash)
Phone is unlocked (check with *#7465625#)
For Model:
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type*#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# andhit the Call button. Turn off and insert another Simcard. Turn on. The code is00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) untilphone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter#0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung SGH600
*2767*3855#
*2767*2878#
Model: Samsung SGH2100
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
Model: Samsung Universal
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Youwill get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
d500 - #*7337# - ( but not in the newer software versions )
update 04/02/07
1. If you have changed your phone password, change your password back to thedefault 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, thenSIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone islocked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This will rebootthe phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization"or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK mentioned earlier getsswitched back on)
10. Completed. You have now unlocked your phone.
tested on e900 and d900 phones - may work on similar models but not sure
ps this will work with your new sim but if you try anither sim not used in thatphone bofore it will need code doing again
Apr 03, 2011 | Cycling
For some reason Facebook won't accept my email address. Why????
have you tried putting you email address and making sure that capslock is turned off, if so and it still wont accept your email as you say try retrieving your password put your email click forgot password it will prompt you to input your personal for password rest and retrieval, this happened to me as well but I found out I was hacked, because when I got to change my password and enter my facebook all my personal pictures were deleted and messages were sent to my friends saying I was hacked with a smiling face on the message .
Jun 06, 2010 | Lenovo 3000 Y410 Notebook
My samsung pixon keeps freezing. I can turn it on
This is courtesy of Helifix from Handcellphone.com...
Hello Guys. I have the same problem and I found out the solution. The problem is a faulty contact from the touchscreen leading to the phone board. To be short: on the right side of the phone were the volume buttons are, under the touchscreen is the screen's contact. Try "detaching the screens face a little from the phone body exactly at the volume down button(using ur fingernail or something) and see if the touchscreen is responding in anyway. My phone has a bad contact there, and in normal mode all is frozen. Now if I try to pull towards me, the touchscreen frame from the rest of the chassis, only a mm SURPRISE!! My touchscreen is working. IF this is your case too...I suggest get a screw-driver and open the chassis, and trying to make the connection permanent, somehow. I haven't done this yet, but will do it today. If anyone is interested I could post the results:) PS: you can send it back to warranty of a repair phone shop, only to force you to buy a new touchscreen and pay for the repairs, on a 99% working phone, with a faulty contact. The choice is yours:)
Nov 19, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
PUK and PIN code for a Samsung SGH-A117
Samsung D500
Switch phone on without sim and enter :-
#*7337#
if it does not work then you need a direct unlock in a shop
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another Simcard. Turn on. The code is 00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) until phone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8 digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter #0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
*2767*3855#
*2767*2878#
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
Jan 19, 2009 | Cell Phones
HTC Touch HD Smartphone Logo
1,109 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
