I have a (2009 )WM0642HW.The new ones don't have the Forced Water Recirculation Nozzle that's in the top of the door seal. LG quietly (discontinued) that feature. If you do see a WM0642HW with a spray nozzle in top of the door seal in a showroom somewhere, it was a WM0642HW manufactured ( assembled ) a long time ago.Currently produced WM0642HW will not have the Water Recirculation feature installed. There may still be some older version "new" WM0642HW units out there somewhere? But most of them are display models or unavailable ,and with a shorter motor warranty. 7 years instead of current 10 years on new versions of the WM0642HW.But getting back to your question, the washer fills by water entering the cylinder through the back top left side of drum as it flows from the dispenser compartment via a hose.The opening is right behind the cylinder baffels location. It has no fill nozzle at the front gasket edge like some other brands have. My washer did not clean well at all with full loads. Only after i turned the water level switch under the top lid "clockwise" a half turn ,does it now fill up to the bottom of the door rubber seal.My clothing now tumbles in a pool of water instead of a WICK WATER RUB WASH that it was doing previously. It's a 100 times better with the few gallons of extra water inside, BELIEVE ME. What i say is from experience with this exact model.Turn up the water level so it can tumble in some water. TRUST ME ON THIS ONE! You'll have nothing but grief until you've had enough and have the desire to turn it up alittle.Just have it set to fill to the bottom of the door gasket.Everything will be saturated at the start of the wash and not towards the end of the wash segment.
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
