SOURCE: IR2318L CANON COPIER IS SHOWING CODE E000003-0000
IR2318L CANON COPIER IS SHOWING CODE E000003-0000 AND HAS STOPPED COPYING,WHAT COULD BE THE PROBLEM?
SOURCE: Canon iR2318L digital copier/printer is showing
hello,
you need to change the fixing film in fixing unit! The fixing film is worn out!
There is no reset for these type of error! Call service!
Hope that helps!
SOURCE: i M facing paper jam
is it showing some error code.open the fuser unit and then check the pressure roller bushes.sometimes they move from there place causing paper jams.do check whether u have applied right amount of grease to the fixing film and do check whether the white sensor of the film is in right position.u have to just fit all the parts rightly .it has something to do with these said things
