SOURCE: i've noticed that replacement inner
The ear padding is attached to and held in place by a plastic ring that fits into the speaker mount. Gently pull the ear padding outward so you can see the ring, then slip a flathead screwdriver or other object in (just a bit, you don't want to poke the speaker inside). Gently pry up , sliding your pry-bar along, and the pad should pop out quite easily.
SOURCE: I need replacement ear cushions
Check out My tip on headphones, at the bottom of it you will find a link to a place that should have them. Just click my user name to find the tip.
SOURCE: foam ear pads are breaking up
http://www.bhphotovideo.com/c/product/116410-REG/Sennheiser_050757_H_50757_Ear_Cushions.html
new ones available at above link. this is pitty normal, it happens with time, replacing them is easy...
SOURCE: Need replacement ear pads for
http://www.jntworld.com/catalog/index.php?cPath=21_1002¤cy=gbp&osCsid=c5b2f0de48c59564afb36dfebba513ac#tabbed_box_1
Here you will find something.
