Question about Kenmore HE2 Plus Front Load Washer
On a Kenmore he2t I am getting a SD error followed by an F21 error code. I have replaced the pump, but the continue to get the error. What would be the next step?
Model #110.47561601, After replacing the drain pump and checking the drain hose etc., I continue to get the F21 error code. What would be the next step?
    Sergeant:
  • 419 Answers
Could be door lock or main control problem
Posted on Dec 10, 2013
Testimonial: "Thanks to all for the responses! All the recommendations have been followed, so I guess it is time to throw in the towel! I now assume that I have a pressure switch or CCU problem. We will see!?!"
6ya staff
SOURCE:
Anonymous
  • 639 Answers
SOURCE: F21 error
Peace Friend,
ngfam1 At your service!
NO GOD FOR BID DO NOT USE DRAIN OPENER IN AN APPLIANCE!
First try this, unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 02, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Posted on Sep 23, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Washer will not drain properly.
"F21" is a Long Drain error code. This may be an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
https://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
https://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If there is no screw off cap on the pump, you need to remove the large hose that connects to the inlet side of the drain pump.
Posted on Jan 19, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: How do I fix drainage problem code F21 on Kenmore
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
https://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
Brian Manuel
  • 354 Answers
SOURCE: need part number for my
Sears has a fantastic part locator on line try that just surf the sears site you ll find it ,probalby even have a number to call just in case
Posted on Mar 09, 2011
I have a Kenmore HE2t i keep getting error f21 i cleaned the trap and it still does it
You may have to unplug it for about 15 minutes and try again. I had a similar problem and this helped.
Mar 19, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
I have a Kenmore HE2Plus - it is 6 years old. All of a sudden two days ago I got up to a load of laundry not done, full of water and the code F21. We have gone through most all of your suggestions. At...
The Sd code appears when sud is detected but it may also indicate draining problem such as blocked drain filter or broken drain pump as signified by the long drain error code F21. The drain pump impeller may be broken or restricted resulting in poor draining or no draining at all or the drain pump motor is faulty. Since the drain hose and filter have been cleaned but the error code still persists, the drain pump likely needs to be replaced. Click on the link below for the detailed troubleshooting instructions.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing
Jun 18, 2011 | Washing Machines
My HE2t was washing and then stopped with an F21 notice and when I retried it the door does not double click and it sounds like the pump is runnig..
The F21 error code indicates a "long drain". If the unit is draining correctly I would recommend checking the pressure switch & hose. Another possibility would be the air dome.
Jan 06, 2011 | Kenmore Washing Machines
F-21 error on my Kenmore HE2t
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Jun 15, 2010 | Kenmore 44102 Front Load Washer
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Get the f21 error code, does not go away. Also
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 30, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore he2t error code 21
Sep 23, 2009 | Kenmore Washing Machines
How do I fix drainage problem code F21 on Kenmore HE2t washer even though I already checked and drain hose is NOT clogged and is more than 96'' above the floor.
Jun 07, 2009 | Kenmore HE2 Plus Front Load Washer
HE2t front loader displays f 21 error
May 09, 2009 | Kenmore Elite 45986 Front Load Washer
New pump didn't fix error F21
Feb 04, 2009 | Kenmore 44072 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
261 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
