You can find videos about removing the door panel and the exterior door handle on YouTube, so I will not cover those in this post. Other posts about this repair involve things like drilling a hole and inserting a bolt into the broken plastic handle, but if the breakage is in the area where these photos show, those fixes can fail in time. This fix reinforces and improves the faulty design of the part; in other words, auto makers (including BMW!) use plastics where metal, such as light-weight aluminum, should have been used. INSTRUCTIONS: 1. Remove the interior door panel. 2. Peel back the plastic covering from the door to access the door's interior cavity. 3. Remove the 2 10mm bolts on either side of the handle securing the door handle to the body. I recommend a ratchet wrench for the easier-to-reach nut and a socket for the other. 4. From the outside, pull the door handle out enough to reach the lock and opener rods from the plastic connectors on the handle so you can remove the handle from the door. 5. Remove the metal door opener arm from the handle. One bolt holds it in place. 6. Fashion a "splint" from a 1" X 1" piece of aluminum. It should be thin enough (about 2 or 3 millimeters thick) to wrap around the broken handle arm as shown in the attached photos. Be CAREFUL not to damage the other plastic handle components. In my photos, it appears a previous owner tried to repair the breakage with a thin bolt. You can see the dried, cloudy-colored glue beneath my aluminum splint. Be sure your splint is wrapped tightly around the broken arm so that the arm cannot come apart again. Good pliers are essential here to bend the aluminum splint as shown. 7. Once completed, reattach the metal opener arm to the handle and ensure the spring end rests in the notch of the arm. 8. Reattach the handle to the door body, ensuring the rods are back in their proper plastic "hooks". You cannot attach them incorrectly, as they only fit one way. Removing and reattaching the screws inside the door cavity can be tricky. The door frame edges are sharp. Be patient and careful not to cut yourself. It will probably take a good five minutes or more to get the screws back in place and tightened.
The inside handle or the outside? to get the outside handle off you need to remove the inside door panel. It's wise to remove this panel in a warm place as the plastic parts and clips ten to break instead of pop apart as they don't bend well when cold. With the panel removed theirs a plastic seal that can be removed and you can see inside the door. looking at the handle from the back side thier'll be nuts holding it on. If you have the replacement handle you'll see the atteching points on it. If the handles broken thiers no point in removeing it until a new handle is in hand. If your not sure the handle is broken but need to remove it to find out, it's wise to it completly badck together even if it's not fixed so all the parts are where they belong not laying around to get lost or damaged.
There are only 2 places that you have the problem on the inside door handle. one is at the handle,and the little plastic holder that holds the rod to the handle broke, or the plastic clip the the door lock mechanism broke. the first can be removed without taking the door apart. the inside door handle has a screw holding it in place. you can remove the handle and see if its broken. the second requires you to remove the door panel, to replace the clip that hold the rod to the lock. I door handle in the car is a dealer item only(sorry to tell you that), the clip for the lock, you can get at the auto parts store. hope this helps
u have to take whole door apart to get to it . remove the door then take screws out from bottom and sides then u can removbe the glass to see the other screws helping to hold handle on
There is a cheap plastic retainer on the end of the rod that holds it to the handle. Get a Wheel color from a RC airplane hobby shop and use it to hold the rod on the handle. Works better than the original clip. You don't need to take the door apart for this, you can usually reach the rod after removing the interior latch handle.
