Question about Dell OptiPlex GX620 PC Desktop
I HAVE A BLACK FRONT GRILL & NEED TO REPLACE IT. CAN I BUY JUST THE FRONT OR DO I HAVE TO BUY THE WHOLE DESKTOP CASE & WHERE? & HOW MANY $ $ ?
I HAVE A DELL OPTIPLEX GX620 DESKTOP THAT HAS A RUINED FRONT BLACK GRILL PANEL. CAN I BUY JUST THE FRONT? OR DO I HAVE TO BUY THE ENTIRE DESKTOP CASE? WHERE & HOW MUCH? DNHUFFORD@HOTMAIL.COM
  • Dell Master
  • 5,660 Answers
For this solution I would suggest contacting Dell, or checking Ebay. You may find an Optiplex GX620 on Ebay for parts, that you can buy for a song. (And sing it yourself)
Should a Front panel Cover not be available, (Or too pricey), you may want to look into buying a new computer case.
You can buy a decent, good looking, new computer case, for around $60 to $80
Then transfer your parts to it.
Here are examples,
http://www.tigerdirect.com/applications/category/category_slc.asp?Lprice=50&Hprice=99.99&CatId=1847
You might also want to check Ebay for this too.
Posted on May 13, 2009
Anonymous
SOURCE:
How do i remove front grille frame from skoda octavia
I have no idea how to remove the front grille of Octavia but to solve out your problem I found out one video which is showing to replace the new front grille with old or damage one. May this video helps you. Have a look
Apr 13, 2013 | Skoda Octavia Cars & Trucks
Acer Aspire Am3470g case removal
I also have an Acer Aspire AM-3470G & just swapped DVD drives trying to troubleshoot a problem. Remove the one side panel with the finger tab that gives you access to the system board/HD's, etc. No need to remove the opposite side panel. With the panel off, there are 3 black plastic tabs holding the front cover on. Release them so that the front panel pivots to the opposite side which also has 3 black tabs. Those tabs will release themselves as you pivot the front cover. You may need a bit of force to pivot the cover so be careful not damage the plastic tabs. You'll now have complete access to the DVD tray area. The DVD is held in by 2 exposed screws, there are none on the opposite side of the drive. Unscrew them, disconnect the power & SATA connectors & slide out the drive. If you replace the DVD drive, test the new one before you reassemble all the covers to verify everything works.
May 04, 2012 | Acer Aspire Am3470g-uw10p
I need to take the Tray Smoker out of my grill to replace the ignitor but it only comes partially out. How do I get it all the way out? I have a KBGS292LSSO grill
When you slide the smoker box and smoker tray out of the face of the grill, you may have to lift up the slightly lift up on the front of the slide, to remove it entirely from the grill. Once the slide is pulled out far enough to remove the smoker box, remove it first and set aside. Then continue to pull the slide all the way out, lifting the front as it reach the face of the control panel.
In case you have misplaced your Owner's Manual, I have included a link to it that you can download & print for future reference. http://www.appliancefactoryparts.com/content/pdfs/150240-2.pdf
Check out page 13, if you continue to have a problem.
I hope this has helped you and thanks for choosing FixYa.
Jul 26, 2011 | KitchenAid KBGN292LSS\KFGR292LSS Grill
Headlamp remove & replace
If it is just burnt out , you do not have to remove or replace the whole lamp , just the small bulb inside of it. They are usually easily accessable from inside the engine compartment , and just come out of the back of the headlight by 1/4 turn.
Jan 28, 2011 | 2004 Buick Rainier
00 peugeot 406 fanmotor not working have checked fuse reostat & motor
behind the front grill inbetween the cooling fans there is a black cover and under this cover there are 2 relays. you need to replace these relays and the terminals as they corrode and brake
let me know if this helps
cheers big mike
Nov 26, 2010 | 2006 Peugeot 604
Remove & replace waterpump on a 2002 volkswagon jetta turbo, is it hard to do. Car overheats at regular highway speed, runs find locally. Please help?
i had a mk4 golf 1.8t there basicly the same and its not that hard to do the whole front of car come off so you can work on it very easy grill off then bumper then you see the 8 or so bolts holding bash bar and whole front end on undo and you have all the room in the world if you need more detailed steps email me i have a haynes manual i could scan a few pages if you need shaunhoop1981@googlemail.com
Jun 05, 2010 | 2002 Volkswagen Jetta TDI
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Red convergence will not line up on my jvc 56 inch i art projection tv model # AV-56WP74. PLEASE TELL ME WHERE CAN I BUY THE KIT SO I CAN FIX IT MYSELF!!!
You need to pull the front grill cover/panel off the front of the tv. Remove screws (4) from back that hold it on, also 2 small ones behind front video input door. Then remove access panel. The ckt board closest to you is the convergence amplifier board. You should replace both amplifiers (stk392-110 or 120) and any burnt/open resistors you find near the amps.(use the same value resistors as the corresponding resistors in the blue amp ckt)
Jul 08, 2009 | JVC AV-56WP30 56" Rear Projection...
Dell OptiPlex GX620 PC Desktop Logo
180 people viewed this question
Ekse
Thomas F. Schneider
Shawn DuRee
